wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-10-30T01:27:24+00:00
    Sorry, did everything JavanClark suggested including device refresh and still can't get large-ish files over my network. Weird thing is that I was able to stream Netflix for about an hour last night.
