wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-10-29T20:52:08+00:00
    Hey all.
    Here are a couple of steps we need you to do for us.
    Restart the device.
    Please be sure all available device updates have been applied.
    The next step would be to Forget Network.
    • Select the Connections indicator in the lower left hand corner of your screen. This will list the available Connections in your area.
    • With your fingerSelectand Hold, or with your mouse,right click the connection that you are connected to. A context menu will appear. Select the Forget Network option.
    • Once your Surface has forgotten the network, try to reconnect to that network.
    If the above steps don't correct the issue please perform a Device Refresh.
