wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-10-29T16:52:45+00:00
    I've seen this happen on my x86 Windows 8 tablet, it seems to be possibly and issue with Windows 8 rather than the Surface itself.
    Not seen it happen on my laptop though, I presume its possibly something to do with the wireless adapter going into power saving mode or something.
