wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-10-29T15:24:53+00:00
    I need to amend my earlier submission.  Last night I was also not able to get 1.6 GB video file across my home network via Homegroup.  I killed everything in Task Manager before trying all three times but could only get about a gig each time before it froze and I had to reboot. Don't think it has anything to do with SkyFrive
