wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-11-25T02:22:39+00:00
    I've tried the tweak and so far it appears to have worked. I left the Surface RT running a Netflix video stream for more than two and a half hours straight (previously this was guaranteed to "sap" the WiFi connection to the DIR-645 - at around the 30-minute to 45-minute mark) and it did not exhibit the "limited WiFi" issue. And it is still working!
    If this is indeed the fix, follow the steps below....
    From the admin-level command prompt in Desktop mode, type the following commands:
    • netsh int tcp set heuristics disabled
    • netsh int tcp set global autotuninglevel=disabled
    • netsh int tcp set global rss=enabled
    • Then type netsh int tcp show global to verify that practically all the settings are disabled.
    • Finally, reboot the Surface. (Not sure if this is necessary but I did it anyway to ensure I'm starting from a clean slate - no pun intended).
    Cheers.
