wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-10-29T03:57:17+00:00
    I've been having same issues on and off.
    Failed to help:
    • Upgrade wireless router firmware (Linksys)
    • Refresh Windows 8 (including 4 Windows Updates)
    • Reset Windows 8 (including 4 Windows Updates)
    • Enable broadcast of SSID (was hidden)
    • Verified mutual wireless authentication type (WPA2-Personal AES)
    • Disable DHCP, set static IPv4 address
    • Disable Bluetooth NIC
    I have several other working devices on the same wireless network including; iOS (various), Blackberry, Kindle Fire, Windows 7 (Dell Laptop), and Sony PS3.
