wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-11-22T20:49:54+00:00
    OK Microsoft, you just missed an opportunity to impress an executive board room. Results....not to purchase the Surface and to buy something else.
    As a 30+ year IT professional, I have never been so embarrassed as this. My team went to show off the new corporate mobile web site with several mobile devices such as iPad, iPhone, Android tablets and phones, BlackBerry phones, and of course my personal Surface. Of course, the star of the show was to be the Surface, instead, it never connected to the company wireless. All other devices worked great and as expected. Microsoft received a major black eye for this.
    I have made my living on supporting Microsoft products over the years. And this is very painful to say. "I want my money back".  As I had to drive 3 hours to get to a Microsoft store, 6 hours round trip. I am not doing that again. How do I get my money back and return this door stopper!  You had plenty of time to fix this and plenty of people here who have the exact same issue, yet no press release to let us know you are even working on the issue.
    And with more than 30+ years of IT experience you have not been able to fix it by yourself? The majority of those asking for a fix here are those that do not have any years of experience.
    I understand that this should be fixed but in these many pages many have reported different fixes for this issue.
