wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-10-29T02:35:24+00:00
    I noticed this problem as well on Friday and have experienced it over 25 times. I have noticed one thing though- it happens almost exclusively when I'm accessing Skydrive. This applies to SD app, SD site, and syncing OneNote via SD. Granted, every time its involved large files with long continuous wireless loads. I haven't tried downloading a large file from another website yet but video file transfers over my network seem to work fine.
    Router is a D-link 6xx series.
