wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-11-20T03:57:08+00:00
    I have been having the same issues left and right but my husband has been lucky with his (no issues). I will probably reset my surface tonight since its been a tad glitchy. I have turned off the option tonlet the WiFi wake the surface and it has fixed my limited connectivity issues. I was having issues connecting sometimes but I cannot test that yet.
    So maybe try turning off waking.
