wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-11-19T01:24:05+00:00
    We bought the product so that it would work like every other wifi device.  Please stop posting these odd fixes that tech geeks would only know how to install or apply.  MS needs to provide us with a proper update that addresses issues that neither the ipad or any other android tablet have.  I've used a lot of devices and this "limited connectivity" thing has never been a problem until I bought the surface.
    Sorry, I'm trying to help and gather more info useful for a final fix. If you do not understand what I'm asking to do, please ignore my posts.
