wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-11-15T12:18:39+00:00
    I have had no problems at all with WiFi since the update.
    Using my Android phone as a WiFi access point has been a joy today.  If I take the phone out of range and bring it back again, the Surface instantly reconnects.
    So far, so good.
