wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-11-14T19:48:10+00:00
    Since yesterday's update it is worse than ever for me. Impossible to open 2 web pages, wifi goes limited and i have to turn it off. When i switch my router from wifi-N to wifi-B/G no problem at all.
    which pages are those? maybe we can reproduce
