wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-11-11T22:45:36+00:00
    Exactly, there seems to be a problem with surface for this setting. after I changed the power setting, the surface won't wake up from sleep even I know it is on. I couldn't even restart the machine without encounter the blue screen of death, then the machine is forced to reboot. Even though change the power setting in the network card is not a workaround, I suggest Microsoft to take a look at it anyway, there are clearly issues...
