wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-11-11T20:39:15+00:00
    Turning off the power saving seemed to totally knobble the standby and I was unable to wake the Surface as the screen would not turn on.
    Needless to say I don't recommend this work around, although it did seem to solve the dropouts
