wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-10-28T03:55:13+00:00
    From what I can tell this is directly related to the Surface not identifying the security protocol for the wireless network correctly.
    For example, I tried connecting to my Actiontec Q1000 Wireless Router and I was getting a "limited" network connection. After investigating the router settings, I finally looked at the wireless adapter settings in:
    Desktop > Control Panel > Network and Sharing Center > Change Adapter settings > Double-tapped the Wi-Fi connectio to bring up the properties panel > Wireless Properties > Security.
    Here under Security Type: the Surface was trying to connect to my wifi network using WEP, and my router was only set for WPA/WPA2. So I changed the Security type to the correct one (WPA-Personal) entered the password, and it connected. Full internet and everything.
    I haven't had a problem since. So, moral of the story, check the security protocol for your wireless network that you're connecting to, then make sure the wireless adapter settings are set to the same security settings.
    iBrent
