wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-11-08T13:56:37+00:00
    richard,
    Yes it should just work but if you've spent any amount of time around technology you'll understand that isn't always the case. Shall I remind you of iPhones reception issue? Should just work right?
    There is a work around that seems to work, Microsoft is aware of the problem and I can say that's a pretty quick response or acknowledgement of an issue over most tech companies.
    Have some patience and im sure then proper fix will be rolled out soon.
