wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-11-08T16:44:15+00:00
    Greetings everyone,
    We are aware of the issue with the Surface dropping the connection to Limited. We are currently investigating the issue.
    At this time, I would like to know if you can switch your routers to run on 802.11 G and see if the issue persists.
    When I switch to g or b&g, the problem goes away.
