wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-11-19T01:13:24+00:00
    I am just technically intrigued to hear eventually what the problem is -- regarding the trouble of connecting to networks.
    From this thread, it appears that the problem is not plainly about different software / user profiles.
    For instance, I use tons of different networks and I am sort of fine now. (In some cases, I still have to disconnect and reconnect, but that's seldom now.)
    So interestingly, the problem is almost inevitably about hardware / chipset variation / lack of software adaptiveness in response to such variation.
    Though, the thing with not picking up a nearby spot and hanging on the remote one seems to be a software problem.
    Just guessing.
    I couldn't be more satisfied with the experience otherwise.
    Ralf
