wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-11-30T20:44:39+00:00
    Got annoyed this morning so I have now set my router WNDR3800 using open source dd-wrt firmware to use only G on the 2.4ghz range and only N on the 5ghz side, I run the router sharing the same SSID,
    I will see if the dropouts become less frequent or even stop......
    So it seems the Surface prefers the 2.4Ghz side of my network and since dropping the speed back to old G 54Mbps speed, the connection has not gone limited, I keep checking and it's staying on the G side.
    I just updated Adera and Parking Mania which would guarantee a loss of connection but this time went through solidly (albeit slower)
    My laptop prefers the 5Ghz......
    Until the fix is issued, and if you have the rights on your router I recommend this workaround
