wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-12-03T22:43:01+00:00
    No, not heard a thing. still having the same issues on all surfaces even on differing networks. I did speak with the helpdesk and they acted as if they had never heard of the issue. To be honest I think its a disgrace that Microsoft have been so vague with this issue and are taking so long to fix it. It's been reported in a lot of magazines and forums and the publicity will be very alarming to those who are considering purchasing a device. The very basics to get right is internet connectivity....  without that the product is dead in the water. maybe they should divert 1% of the marketing budget to fixing the widely reported issue that will undoubtedly effect sales.
