wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-12-04T03:44:06+00:00
    My Surface is permanently stuck on Limited whenever I try to connect to my phone's hotspot. The problem is, it did work for about a week of switching between home and phone wifi before deciding to fail. I reset up the hotspot with a new SSID and that worked for about a week too. Now it simply refuses to get beyond Limited no matter what I try.
    It still works with my home wifi. Now I don't have the configurability on my phone that I would have on my home router so many of the (functionality-breaking!) tweaks suggested here are not an option. But that is not the point - my original iPad that the Surface RT was intended to replace has no problems whatsoever on either network. Right now the Surface is only good for around the house and useless anywhere else.
    Things that I've tried multiple times in various orders which have failed:
    reboot, forget network, airplane mode
    all the network troubleshooters
    disable/enable wifi device
    uninstall/reinstall wifi device
    'refresh' Surface RT
    mid-November firmware update
    When I tried ipconfig /renew (or /release) in an administrative cmd window it gave an error message referring to virtual adapters or drivers #10 and #13. I don't recall the exact wording because I'm at work and of course the Surface is sitting around being useless at home.
    Are #10 and #13 phantom bindings or something? If so there is something seriously wrong here. Just to make things worse, my Bluetooth is also frozen, error Code 43. None of the KB articles on Code 43 appear to be usable on the Surface RT and the refresh/disable/enable & troubleshooters failed here too. I will be returning my Surface for a refund and am happy to buy a replacement or better model down the track because I really like the OS on a tablet.
