wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-12-04T11:59:27+00:00
    So my surface is pretty much useless. I cannot connect to my wifi at home as its constantly in limited mode.  It worked for bit when I got back but now nothing.
    Can we please have an update on this issue? Has anyone got a workaround for this?
