wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-12-12T12:39:19+00:00
    Although I agree this has to be permanently fixed by MS, you can force your surface to use wifi b/g only through the registry as advised in a previous post, that will solve your limited connection issue and you will not see a significant speed difference while browsing the web.
