wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2012-12-30T22:33:56+00:00
    I agree. I have been having problems with mine since it came out of the box. Constant limited connectivity mainly in the middle of downloading. I have adjusted my router and all settings on the surface and at most I get 30-40 mins before being kicked again.
    I sure hope there is a work around soon because with out carrier coverage I am sitting here with an expensive paper weight.
