wifi issues
2012-10-28T18:24:01+00:00
Nate
Surface | Other
2013-02-19T00:22:07+00:00
Greetings all,
2013-07-26T22:53:04+00:00
Greetings everyone,
Connect to a wireless network
2013-08-20T01:28:23+00:00
2013-05-26T21:44:35+00:00
Hello priscillaodendaal,
Let us know.
Best regards.
682 additional answers
    2013-02-05T00:34:35+00:00
    I hadn't used my Surface in weeks.  Turned it on and it connected to my wireless like it should.  It's like it needs to forget the home wireless to be able to reconnect to it.
    I'm baffled and will continue to use the device until the problem occurs again.
