Surface Pro 4 - External screen keeps turning on/off (black flickering)
2017-06-13T21:32:22+00:00
Hi there,
I just made a video of my recent problem: https://www.youtube.com/watch?v=Phi\_Yru77aM
You can see that when I'm using the built-in screen of my SP4 (i7, 16GB, 512GB) and only one 4K external screen (both at 60hz), this monitor keeps turning black on a random basis. All my drivers and firmware are up to date (Surface Dock and Surface). I even tried the last Intel Iris 540, same results. I tried another MDP to DP cable, same results. I tried another screen, same results. I tried different refresh rates, same results.
I bought this screen a month ago and I was working fine at the beginning. I strongly suspect an update or the fact that I tried to connect two 4K monitors at 60hz (and I would have damaged something in the process?).
If I deactivate the built-in screen, the problem goes away (something that I just found tonight).
Should I send the device in warranty or just wait for a software fix? The 4K experience is not there yet, I'm a bit disappointed I have to say.
Cheers,
D.
    2017-08-28T01:37:47+00:00
    We appreciate the information you provided. To further troubleshoot the issue, you can try these steps:
    1. Restore your Surface Pro 4 to the earlier time before the issue started;
    2. Reset your Surface Pro 4 while keeping your files;
    3. Download and reinstall Windows using a recovery image.
    Before doing the suggested steps above, we suggest that you back up all your files to an external drive.
    Regards.
    2017-08-29T10:45:08+00:00
    Thank you for the answer. I prefer to wait and see if the logs that DulcowX has provided will lead to something. Else I will try the reset, but I have no free time at the moment. By the way, I have only had two "monitor resets" since I ran the Software Repair Tool. Normally I can have one per 15 minutes. (as a rough average, they are very unpredictable).
    2017-08-30T07:09:19+00:00
    Hi Erwin,
    Sorry but reset the device is a painful process which does not seem to work (other people tried this and the problem keeps coming back).
    Can someone from Microsoft have a look to the Feedback Hub report I have provided earlier in this thread? I think that it should be the best way of troubleshooting this problem.
    I can provide you more reports if needed over the weekend. Just let me know.
    Cheers,
    G.
    2017-08-30T14:21:55+00:00
    We appreciate your feedback on this issue.
    Feedback items regularly receive Microsoft responses on the submissions in the Feedback app so you can see what we are doing about your feedback.
    Please revisit frequently to see the status of your feedback items.
    Thank you.
    2017-09-01T08:02:28+00:00
    same problem on 2017 surface pro i7 16gb using mini dp to a dell up3216q
    Same monitor at work is ok I think, more testing needed, this one at home was replaced under warranty a month ago so has newer firmware (one at work is 2015)
    If I open milestone CCTV software it starts flashing off every 5-10s, rather than once a minute, so what's on the external monitor has an effect on the frequency of the flashing
    I expect no amount of resetting will fix this problem, it's probably a driver/firmware incompatibility
    waiting for a dock to arrive today, will see if it still happens.
    No issues into an older HP ZR30W.
