Surface Pro 4 - External screen keeps turning on/off (black flickering)
2017-06-13T21:32:22+00:00
Hi there,
I just made a video of my recent problem: https://www.youtube.com/watch?v=Phi\_Yru77aM
You can see that when I'm using the built-in screen of my SP4 (i7, 16GB, 512GB) and only one 4K external screen (both at 60hz), this monitor keeps turning black on a random basis. All my drivers and firmware are up to date (Surface Dock and Surface). I even tried the last Intel Iris 540, same results. I tried another MDP to DP cable, same results. I tried another screen, same results. I tried different refresh rates, same results.
I bought this screen a month ago and I was working fine at the beginning. I strongly suspect an update or the fact that I tried to connect two 4K monitors at 60hz (and I would have damaged something in the process?).
If I deactivate the built-in screen, the problem goes away (something that I just found tonight).
Should I send the device in warranty or just wait for a software fix? The 4K experience is not there yet, I'm a bit disappointed I have to say.
Cheers,
D.
    2018-05-29T14:00:39+00:00
    Running Windows 10 version 1803 with an Intel Iris Plus 640 and an i7 processor.  I still have the screen blackouts on my Philips BDM4065UC monitor that's plugged into my Surface dock.  I have noticed that two things seem to influence the frequency of the blackouts.
    1. Using Microsoft Edge browser.  If I run with Firefox all day, I don't have much for blackouts.  If I use Edge heavily, they occur all the time.  Sometimes just starting the browser will cause the monitor to flicker.
    2. High CPU - If my processor is running hard, I'll have more blackouts.  I'm not 100% sure yet, but that may be in conjunction with the GPU  usage as well.  I run with Task Manager all day, so I try to keep an eye on the charts when a blackout occurs.
    That being said, these two items can't be reproduced on demand.  I just know it increases frequency.  Leads me to believe this is definitely a driver issue.
    2018-05-31T14:11:04+00:00
    Sadly a manual update to 22.20.16.4749 doesn't fix my off/on issue.
    Like reported by some others, the Windows April 1803 update didn't bring any new driver to me, I was left with 21.20.16.4647. A click on "Update Driver" told me that I was running the latest update.
    I have now downloaded and installed 22.20.16.4749 via the provided link in this tread (thank you very much, by the way). I didn't get any error messages or warnings (like others). I then ran the SurfaceDiagnosticToolkit to ensure that the apps were reset. Still no warnings or errors. I attached my external 4K monitor full of hope. The empty desktop stayed still for half an hour. I then dared to open OneNote; and the 4K monitor immediately started blinking heavily again. For me the blinking is still a factor 1000 worse now than before the Windows 1803 update.  (same for both driver versions, I have rebooted and double checked that the new driver hasn't been overwritten)
    I am now deeply depressed.
    If I recover and find strength again I might test the 20.19.15.4326 and 23.20.16.4973 versions also.
    It is strange that some of you got a newer driver with 1803. Do you also have an Intel Iris Graphics 540?
    2018-05-31T14:28:52+00:00
    @enady - that really sucks. Mine is total fixed. Here is a dump from my system info
    [System Summary]
    Item Value
    OS Name Microsoft Windows 10 Enterprise
    Version 10.0.17134 Build 17134
    Other OS Description  Not Available
    OS Manufacturer Microsoft Corporation
    System Name xxxxxxxxxxx
    System Manufacturer Microsoft Corporation
    System Model Surface Pro
    System Type x64-based PC
    System SKU Surface_Pro_1796
    Processor Intel(R) Core(TM) i7-7660U CPU @ 2.50GHz, 2496 Mhz, 2 Core(s), 4 Logical Processor(s)
    BIOS Version/Date Microsoft Corporation 233.2110.770, 1/30/2018
    SMBIOS Version 3.0
    Embedded Controller Version 255.255
    BIOS Mode UEFI
    BaseBoard Manufacturer Microsoft Corporation
    BaseBoard Model Not Available
    BaseBoard Name Base Board
    Platform Role Slate
    Secure Boot State On
    PCR7 Configuration Elevation Required to View
    Windows Directory C:\WINDOWS
    System Directory C:\WINDOWS\system32
    Boot Device \Device\HarddiskVolume2
    Locale United States
    Hardware Abstraction Layer Version = "10.0.17134.1"
    User Name xxxxxxxxxxx
    Time Zone Central Daylight Time
    Installed Physical Memory (RAM) 16.0 GB
    Total Physical Memory 15.9 GB
    Available Physical Memory 9.64 GB
    Total Virtual Memory 18.3 GB
    Available Virtual Memory 12.0 GB
    Page File Space 2.38 GB
    Page File C:\pagefile.sys
    Kernel DMA Protection Off
    Virtualization-based security Not enabled
    Device Encryption Support Elevation Required to View
    Hyper-V - VM Monitor Mode Extensions Yes
    Hyper-V - Second Level Address Translation Extensions Yes
    Hyper-V - Virtualization Enabled in Firmware Yes
    Hyper-V - Data Execution Protection Yes
    2018-05-31T23:06:58+00:00
    I don't have the 540 I have Iris Plus Graphics 640 (the top end i7 model). That could be the difference.
    2018-06-01T00:09:57+00:00
    I bought the top of the line i7 Surface Pro 4 when it was released, special ordered with everything maxed out. I have a 540. WTF? When did they start adding 640s to the SP4? And why is this happening in the first place? It was broken, fixed, then broken again...
