Surface Pro 4 - External screen keeps turning on/off (black flickering)
2017-06-13T21:32:22+00:00
Hi there,
I just made a video of my recent problem: https://www.youtube.com/watch?v=Phi\_Yru77aM
You can see that when I'm using the built-in screen of my SP4 (i7, 16GB, 512GB) and only one 4K external screen (both at 60hz), this monitor keeps turning black on a random basis. All my drivers and firmware are up to date (Surface Dock and Surface). I even tried the last Intel Iris 540, same results. I tried another MDP to DP cable, same results. I tried another screen, same results. I tried different refresh rates, same results.
I bought this screen a month ago and I was working fine at the beginning. I strongly suspect an update or the fact that I tried to connect two 4K monitors at 60hz (and I would have damaged something in the process?).
If I deactivate the built-in screen, the problem goes away (something that I just found tonight).
Should I send the device in warranty or just wait for a software fix? The 4K experience is not there yet, I'm a bit disappointed I have to say.
Cheers,
D.
    2017-06-14T14:09:36+00:00
    Thanks for sharing us the video. While Surface Pro 4 is compatible with external monitors, these are limited to certain models in the market. Monitors that are not found on the list may possibly encounter flickering issues or full non-compatibility.
    If your monitor is found on the list, we suggest that you follow the steps below:
    Go to Start , and select Settings > System > Apps & Features, and check to see if Duet Display is listed under installed software. If Duet Display is in the apps list, uninstall it.
    Let us know if this resolves the issue.
    Regards,
