You can return it, but only within 30 days. The discussions above are about what happens AFTER your 30-day return period. After that time, you can only have a SP2017 replaced on the warranty—i.e., there needs to be a defect or some other defect a warranty covers. But Microsoft does not consider this a defect, so you will most likely not be able to have it replaced under a warranty after your 30-day return period expires.
Surface Pro 2017 Backlight Bleed
Question: Why isn't Microsoft acknowledging the new Surface Pro 2017 display backlight bleed defect and ignoring its customers after the launch of the product? When will they solve the problem? Because all of the units have the defect and replacing it at the Microsoft store is not a viable solution at the moment.
My new Surface Pro 2017 core i7 8GB (lot 1722) has backlight bleed on the whole bottom edge and left side of the screen. You don't normally notice it in landscape mode because the black taskbar hides it, but if you read a white background fullscreen article in portrait mode it's pretty obvious with one side of the screen being brighter than the other side.This light bleed is most noticeable in the colours blue and white and harder to see in black colours (which are usually used in backlight bleed tests).
The quickest way to test and see if your screen has this problem is to press CTRL+ALT+DEL and bring up the blue screen. On the bottom of the blue screen you should see a bright blue/white bar compared to the rest of the screen which is the defective light bleed. All the showcase models in the Microsoft Store I looked at had this problem. I have yet to see a new Surface Pro without this defect. Can anyone post a picture of their CTRL+ALT+DEL screen without the light bleed?
I think people who claim not to have it aren't looking close enough to notice it. Is Microsoft going to acknowledge this display defect and are they working on fixing it in future batches?
Also, if I wait more than one month to exchange my Surface Pro would I get a refurbished model or a new one? If they are going to give me a refurbished model I might as well just return this defective device and get a full refund. When we pay premium prices we expect premium quality. This defect would have been acceptable on a cheap tablet, but not a Microsoft product. Please fix the issue as soon as possible!
Tip: If you want to test your screen on different colours go to http://www.deadpixelbuddy.com/ and choose a colour then switch to fullscreen (win key+shift+enter on Edge or F11 on Chrome) and view the fabulous results and take a picture and post it here so we can prove that it's a universal problem.
I AM NOT THE SOURCE OF THE PICTURES BELOW, THEY ARE FROM REPLIES TO THIS POST OR REDDIT LINKS GIVEN BELOW. THE FIRST PICTURE (WHICH HAS BEEN USED IN TECH NEWS WEBSITES) BELONGS TOWALMART MARKETING TEAMUSER ON REDDIT! I HAVE ONLY GATHERED THEM HERE.
Subreddits discussing this topic:
https://www.reddit.com/r/Surface/search?q=backlight+bleed&sort=new&restrict_sr=on&t=month
https://www.reddit.com/r/Surface/comments/6iji8k/surface_pro_2017_backlight_bleeding_survey/
https://www.reddit.com/r/Surface/comments/6k94qe/just_bought_my_new_surface_pro_2017_i_might_be/
https://www.reddit.com/r/Surface/comments/6jggz5/is_this_light_bleed/?st=J4X9C9Y6&sh=319ae1cc
https://www.reddit.com/r/Surface/comments/6jigz0/whats_your_surface_pro_2017_lot_number_any_issues/
https://www.reddit.com/r/Surface/comments/6kv9ky/light_bleed_on_surface_pro_2017/
https://www.reddit.com/r/Surface/comments/6i8lcz/backlight_bleeding_surface_pro_2017_i5_8gb/
https://www.reddit.com/r/Surface/comments/6j8hau/picked_up_brand_new_surface_pro_i7_512gb16g_ram/
As you can see there are A LOT so do not deny the defect and claim it's a minor issue in a few models. TAKE RESPONSIBILITY MICROSOFT!
Edit: I just realized I posted the original issue as a discussion post and therefore it didn't have the requirement for it to be responded like a question, so I'm editing it so people can also click the "Me Too" button until we get an official/semi-official response from a Microsoft representative. I've also added more subreddits and pictures.
UPDATE (17/07/2017 11:25 AM GMT): The broken image links have been fixed.
**ACKNOWLEDGEMENT:**A lot of tech websites have reported the issue and especially used the first image in this post and attributed it to me. I must note that none of these images are mine and they all come from the reddit posts I linked below them. The specific top image is from the user WalmartMarketingTeam
2017-09-09T19:01:54+00:00 -
2017-09-09T20:46:08+00:00 I just received mine via the Surface Plus program and you guys are saying I can't get it returned due to the light bleed? )':
I got rid of my old device because I thought I was upgrading. I'm a digital artist and the light bleed is too much for me to comfortably ignore.
I think EMilissa's post clearly demonstrates the light bleed issue. Also, I think many feel the same as she does, digital artists or not.
I am adding to her posting with my comments, which I hope are helpful to all, even those at Microsoft.
This light bleed issue has been ongoing for a while, and there seems to be no response from Microsoft (yet). What does that mean? And so, I am making this posting in the hopes this issue gets some attention from Microsoft. Maybe even Panos Panay, Microsoft's head of hardware, will see this post.
I while back I contacted a research scientist named Dr. Raymond M. Soneira regarding this light bleed issue and he unexpectedly responded to me via email with his opinion.
Before I provide his response, posting his impressive credentials is, I think, helpful. His background and credentials strengthens the credibility of this post. For the record:
“*Dr. Soneira obtained his Ph.D. in Theoretical Physics from Princeton University, spent 5 years as a Long-Term Member of the world-famous Institute for Advanced Study in Princeton, another 5 years as a Principal Investigator in the Computer Systems Research Laboratory at AT&T Bell Laboratories, and has designed, tested, and installed color television broadcast equipment for the CBS Television Network Engineering and Development Department.*He has authored over 35 research articles in scientific journals in physics and computer science, including Scientific American.”http://www.displaymate.com/about.html
And so as I was saying, Dr. Soneira kindly responded to my email request regarding this light bleed issue. (Please note: I do not know Dr. Soneira and have never corresponded with him before. Nor have I conferred with him afterward except to thank him for his response to me.) Dr. Soneira has a company that does LCD testing, and in fact, he on a previous occasion performed an excellent Surface Pro 4 technical review, which seemed prompted by Microsoft; they provided him with a Surface Pro 4 (to test). His company, DisplayMate Technologies, tested the Surface Pro 4 with “well-known objective and comprehensive display Lab tests, measurements, and analysis.” The purpose of those tests, the review said, “is to explain in-depth display performance results for consumers, reviewers, and journalists.” The link to that review is:
That article was not about the “New Surface Pro”. And so I emailed the Dr. Soneira about the current “New Surface Pro” and its light bleed issue along with a link to this forum’s thread, and he kindly replied to me with the following comments. He said:
Almost all edge lit LCDs show some degree of backlight edge leaks and hot spots (sometimes from individual LEDs in the backlight assembly). We check for leaks and hot spots using an all blackfull screen test pattern viewed in the dark, which is extra sensitive for this.”
Normally most leaks and hot spots are not visible when viewing normal content. When looking at screen content that has a white background, like in many text applications, the light bleed is unlikely to be noticeable. But for photo and video content, particularly for letterboxed widescreen movies that use black borders, the light bleedcan really standout and be rather objectionable.
The screen shots in the link you sent[in this forum’s thread] show rather considerable visible leakage on a blue background screen.This is either a design or manufacturing defect. Microsoft should replace such defective units.
Raymond Soneira
President of DisplayMate Technologies Corporation
I appreciate these comments of Dr. Soneira's because he is an expert. His credibility would be hard to question in the technical world, and I think his opinion will be useful to anyone attempting to assess this issue objectively.
I, as a Microsoft customer, find this “New Surface Pro” light bleed issue to be a disappointment as I am sure it is to others, especially for those willing to pay extra for a premium product. I have bought serveral Surfaces for my company, and I’ve noticed that my average user doesn’t always notice this light bleed problem and are they are willing to live with it; probably because it gets issued to them and the company is paying for the device, not them. If they had to pay, I think they'd protest.
Regardless of who is the end user -- employee or private party -- this light bleed issue should not be considered acceptable for a product claiming to be a premium product, which also has a premium price.
2017-09-10T22:25:42+00:00 It's outrageous that there's still no response from Microsoft about this. They're keeping their head in the sand.
Deleted
2017-09-13T11:49:35+00:00 Hey I used your test image in portrait mode and on my Surface Pro I could only see a tiny amount of dark when it was full screen against the side with the issue so it dramatically decreased the brightness in that area by the same gradient on your image, but my machines seems to have slightly less of a brightness issue compared to yours in that case.
