Plugged in, not charging and if I unplug that AC adapter, it turns off
2017-01-23T01:46:36+00:00
I have a Surface Pro that is a little over 2 years old. About two weeks ago, the battery now reports "Plugged in, not charging" and seems stuck at 60%. I say seemed because if I unplug that AC adapter, it dies instantly. It also will die periodically while on the charger. I have two Microsoft AC adapters and neither of them seem to charge my device.
I've tried all the Microsoft suggestions for this state, but none of them made any difference. Is there a way to diagnose if this is a hardware problem, or is this a new artifact from the latest updates? (My device reports it is up to date.) I never had any battery issues before (lucky, I suppose), and I've treated my surface pretty carefully. I'll be more than disappointed if it's crapped out already.
I'll attach a battery report, but I don't think it tells me anything in particular.
Battery report
COMPUTER NAME ORION
SYSTEM PRODUCT NAME Microsoft Corporation Surface Pro 3
BIOS 3.11.1550 06/30/2016
OS BUILD 14393.693.amd64fre.rs1_release.161220-1747
PLATFORM ROLE Slate
CONNECTED STANDBY Supported
REPORT TIME 2017-01-22 19:53:16
Installed batteries
Information about each currently installed battery
NAME X898289
MANUFACTURER SIMPLO
SERIAL NUMBER 1164122628
CHEMISTRY LION
DESIGN CAPACITY 42,157 mWh
FULL CHARGE CAPACITY 33,212 mWh
CYCLE COUNT 310
Recent usage
Power states over the last 3 days
2017-01-20 09:41:00 Active AC 60 % 19,851 mWh
09:44:00 Battery changed AC - -
09:44:00 Suspended - -
09:45:28 Battery changed AC 60 % 19,851 mWh
09:45:28 Active AC 60 % 19,851 mWh
09:45:48 Connected standby AC 60 % 19,851 mWh
09:45:49 Suspended 60 % 19,851 mWh
09:46:25 Connected standby AC 59 % 19,494 mWh
09:46:25 Active AC 59 % 19,494 mWh
2017-01-22 19:38:00 Suspended 59 % 19,494 mWh
19:38:45 Active AC 59 % 19,494 mWh
19:50:00 Report generated AC 59 % 19,494 mWh
Battery usage
Battery drains over the last 3 days
Usage history
History of system usage on AC and battery
2017-01-14 - - 4:18:11 -
2017-01-15 - - 23:59:59 -
2017-01-16 - - 23:59:59 -
2017-01-17 - - 23:59:59 -
2017-01-18 - - 23:59:59 -
2017-01-19 - - 23:59:59 -
2017-01-20 - - 23:57:53 -
2017-01-21 - - 23:59:59 -
Battery capacity history
Charge capacity history of the system's batteries
2017-01-14 33,212 mWh 42,157 mWh
2017-01-15 33,212 mWh 42,157 mWh
2017-01-16 33,212 mWh 42,157 mWh
2017-01-17 33,212 mWh 42,157 mWh
2017-01-18 33,212 mWh 42,157 mWh
2017-01-19 33,212 mWh 42,157 mWh
2017-01-20 33,212 mWh 42,157 mWh
2017-01-21 33,212 mWh 42,157 mWh
Battery life estimates
Battery life estimates based on observed drains
2017-01-14 - - - -
2017-01-15 - - - -
2017-01-16 - - - -
2017-01-17 - - - -
2017-01-18 - - - -
2017-01-19 - - - -
2017-01-20 - - - -
2017-01-21 - - - -
Current estimate of battery life based on all observed drains since OS install
Since OS install - - - -
    2016-09-15T02:13:28+00:00
    I'm glad that you partially resolved your problem.
    Regarding battery charging problem, I think that the problem is in embedded controller (EC) because:
    • The full charge capacity is still high when the problem appears (mine still has more than 35Wh).
    • The battery still report correct voltage.
    • The problem with firmware drivers above. Despite we had worked around it, the root of problem is still in EC (something wrong with EC causing firmware installation failure).
    2016-09-15T03:50:15+00:00
    Split from this thread.
    Now change in battery issue not charging when plugged in. latest updates installed "i believe" and has the LGC batteries that say 25% not charging.
    Battery report
    COMPUTER NAME DESKTOP-EF56EU9
    BIOS 3.11.1450 05/27/2016
    OS BUILD 10586.545.amd64fre.th2_release.160802-1857
    PLATFORM ROLE Slate
    REPORT TIME 2016-09-1100:23:28
    Installed batteries
    NAME X883815
    MANUFACTURER LGC-LGC
    SERIAL NUMBER 1181752836
    CHEMISTRY LION
    FULL CHARGE CAPACITY 36,906 mWh
    CYCLE COUNT 2
    Recent usage
    2016-09-1021:46:24 Active AC 26 % 9,637 mWh
    23:12:00 Battery changed AC - -
    23:12:00 Active AC - -
    23:18:00 Suspended - -
    23:22:18 Battery changed AC 26 % 9,629 mWh
    23:22:18 Active AC 26 % 9,629 mWh
    23:22:18 Suspended 26 % 9,629 mWh
    23:37:52 Active AC 26 % 9,629 mWh
    23:50:00 Battery changed AC - -
    23:50:00 Active AC - -
    23:52:00 Battery changed AC 26 % 9,629 mWh
    23:52:00 Active AC 26 % 9,629 mWh
    23:54:45 Connected standby AC 26 % 9,629 mWh
    23:54:46 Suspended 26 % 9,629 mWh
    23:55:23 Connected standby AC 26 % 9,629 mWh
    23:55:23 Suspended 26 % 9,629 mWh
    23:56:22 Active AC 26 % 9,629 mWh
    2016-09-1100:18:02 Connected standby AC 26 % 9,629 mWh
    00:18:05 Active AC 26 % 9,629 mWh
    00:19:01 Connected standby AC 26 % 9,629 mWh
    00:19:02 Suspended 26 % 9,629 mWh
    00:19:42 Connected standby AC 26 % 9,629 mWh
    00:19:42 Active AC 26 % 9,629 mWh
    00:19:42 Report generated AC 26 % 9,629 mWh
    Battery usage
    Usage history
    2016-09-15T06:00:04+00:00
    I'm located in Australia and I have the "70% available - not charging issue".  I've tried all the suggested fixes short of a full reinstall of Windows 10 as I can't see where this has resulted in a fix for anyone.
    I'm holding off on replacement and hoping for an online fix as my SP3 has had very little use (only 11 battery cycles) and any refurbished replacement is unlikely to be as pristine as mine.  Not to mention the hassle of removing data/reinstalling etc.  My SP3 is a 3rd computer and is not used very often.  However, when i do need it i really need it and this whole debacle is making me question my original purchase.  I don't think I'll ever buy a sealed unit again.
    So, I'll be monitoring this thread for any developments - surely Microsoft has engineers who can diagnose the problem and come up with a definitive answer re whether a remote/online fix is possible or whether the unit must be returned for replacement as seems likely ATM.
    2016-09-15T15:34:27+00:00
    Hi Jeremy,
    We're here to help. Were you able to install the 08/29/2016 firmware update? If not yet, you can check it here.
    Keep us posted.
  5. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2016-09-15T16:05:06+00:00
    that update is for SIMPLO batteries only. LGC is a different issue.
