Plugged in, not charging and if I unplug that AC adapter, it turns off
2017-01-23T01:46:36+00:00
I have a Surface Pro that is a little over 2 years old. About two weeks ago, the battery now reports "Plugged in, not charging" and seems stuck at 60%. I say seemed because if I unplug that AC adapter, it dies instantly. It also will die periodically while on the charger. I have two Microsoft AC adapters and neither of them seem to charge my device.
I've tried all the Microsoft suggestions for this state, but none of them made any difference. Is there a way to diagnose if this is a hardware problem, or is this a new artifact from the latest updates? (My device reports it is up to date.) I never had any battery issues before (lucky, I suppose), and I've treated my surface pretty carefully. I'll be more than disappointed if it's crapped out already.
I'll attach a battery report, but I don't think it tells me anything in particular.
Battery report
COMPUTER NAME ORION
SYSTEM PRODUCT NAME Microsoft Corporation Surface Pro 3
BIOS 3.11.1550 06/30/2016
OS BUILD 14393.693.amd64fre.rs1_release.161220-1747
PLATFORM ROLE Slate
CONNECTED STANDBY Supported
REPORT TIME 2017-01-22 19:53:16
Installed batteries
Information about each currently installed battery
NAME X898289
MANUFACTURER SIMPLO
SERIAL NUMBER 1164122628
CHEMISTRY LION
DESIGN CAPACITY 42,157 mWh
FULL CHARGE CAPACITY 33,212 mWh
CYCLE COUNT 310
Recent usage
Power states over the last 3 days
2017-01-20 09:41:00 Active AC 60 % 19,851 mWh
09:44:00 Battery changed AC - -
09:44:00 Suspended - -
09:45:28 Battery changed AC 60 % 19,851 mWh
09:45:28 Active AC 60 % 19,851 mWh
09:45:48 Connected standby AC 60 % 19,851 mWh
09:45:49 Suspended 60 % 19,851 mWh
09:46:25 Connected standby AC 59 % 19,494 mWh
09:46:25 Active AC 59 % 19,494 mWh
2017-01-22 19:38:00 Suspended 59 % 19,494 mWh
19:38:45 Active AC 59 % 19,494 mWh
19:50:00 Report generated AC 59 % 19,494 mWh
Battery usage
Battery drains over the last 3 days
Usage history
History of system usage on AC and battery
2017-01-14 - - 4:18:11 -
2017-01-15 - - 23:59:59 -
2017-01-16 - - 23:59:59 -
2017-01-17 - - 23:59:59 -
2017-01-18 - - 23:59:59 -
2017-01-19 - - 23:59:59 -
2017-01-20 - - 23:57:53 -
2017-01-21 - - 23:59:59 -
Battery capacity history
Charge capacity history of the system's batteries
2017-01-14 33,212 mWh 42,157 mWh
2017-01-15 33,212 mWh 42,157 mWh
2017-01-16 33,212 mWh 42,157 mWh
2017-01-17 33,212 mWh 42,157 mWh
2017-01-18 33,212 mWh 42,157 mWh
2017-01-19 33,212 mWh 42,157 mWh
2017-01-20 33,212 mWh 42,157 mWh
2017-01-21 33,212 mWh 42,157 mWh
Battery life estimates
Battery life estimates based on observed drains
2017-01-14 - - - -
2017-01-15 - - - -
2017-01-16 - - - -
2017-01-17 - - - -
2017-01-18 - - - -
2017-01-19 - - - -
2017-01-20 - - - -
2017-01-21 - - - -
Current estimate of battery life based on all observed drains since OS install
Since OS install - - - -
    2017-04-24T23:34:12+00:00
    I believe we all need to find a good lawyer for a class action suit.  This gas gone on for way too long. I tried going back to factory default and auto update puts me right back to using a very long extension chord so I can still use this product of false advertisement!
    Greg L.
    2017-04-24T23:53:14+00:00
    There's actually a firm out of PA that's in the process of filing one.
    https://chimicles.com/microsoft-surface-pro-3-tablet-battery-defect-class-action-investigation/
    2017-04-25T00:01:03+00:00
    Thats America only.. trying to get one where microsoft are investigated in the uk.. by bbc
    2017-04-25T04:29:27+00:00
    I sent my complaint to the law firm as well as my battery reports.  I have created several battery reports and found they all don't generate the same data, go figure?
    Greg L.
    2017-05-18T12:03:18+00:00
    What can we do about this thing? Its totally unfair for microsoft to be selling such useless devices, i paid a lot of money for this, i would have rather bought an imac then buying this **** that hasnt even lasted me that long.
