Plugged in, not charging and if I unplug that AC adapter, it turns off
2017-01-23T01:46:36+00:00
I have a Surface Pro that is a little over 2 years old. About two weeks ago, the battery now reports "Plugged in, not charging" and seems stuck at 60%. I say seemed because if I unplug that AC adapter, it dies instantly. It also will die periodically while on the charger. I have two Microsoft AC adapters and neither of them seem to charge my device.
I've tried all the Microsoft suggestions for this state, but none of them made any difference. Is there a way to diagnose if this is a hardware problem, or is this a new artifact from the latest updates? (My device reports it is up to date.) I never had any battery issues before (lucky, I suppose), and I've treated my surface pretty carefully. I'll be more than disappointed if it's crapped out already.
I'll attach a battery report, but I don't think it tells me anything in particular.
Battery report
COMPUTER NAME ORION
SYSTEM PRODUCT NAME Microsoft Corporation Surface Pro 3
BIOS 3.11.1550 06/30/2016
OS BUILD 14393.693.amd64fre.rs1_release.161220-1747
PLATFORM ROLE Slate
CONNECTED STANDBY Supported
REPORT TIME 2017-01-22 19:53:16
Installed batteries
Information about each currently installed battery
NAME X898289
MANUFACTURER SIMPLO
SERIAL NUMBER 1164122628
CHEMISTRY LION
DESIGN CAPACITY 42,157 mWh
FULL CHARGE CAPACITY 33,212 mWh
CYCLE COUNT 310
Recent usage
Power states over the last 3 days
2017-01-20 09:41:00 Active AC 60 % 19,851 mWh
09:44:00 Battery changed AC - -
09:44:00 Suspended - -
09:45:28 Battery changed AC 60 % 19,851 mWh
09:45:28 Active AC 60 % 19,851 mWh
09:45:48 Connected standby AC 60 % 19,851 mWh
09:45:49 Suspended 60 % 19,851 mWh
09:46:25 Connected standby AC 59 % 19,494 mWh
09:46:25 Active AC 59 % 19,494 mWh
2017-01-22 19:38:00 Suspended 59 % 19,494 mWh
19:38:45 Active AC 59 % 19,494 mWh
19:50:00 Report generated AC 59 % 19,494 mWh
Battery usage
Battery drains over the last 3 days
Usage history
History of system usage on AC and battery
2017-01-14 - - 4:18:11 -
2017-01-15 - - 23:59:59 -
2017-01-16 - - 23:59:59 -
2017-01-17 - - 23:59:59 -
2017-01-18 - - 23:59:59 -
2017-01-19 - - 23:59:59 -
2017-01-20 - - 23:57:53 -
2017-01-21 - - 23:59:59 -
Battery capacity history
Charge capacity history of the system's batteries
2017-01-14 33,212 mWh 42,157 mWh
2017-01-15 33,212 mWh 42,157 mWh
2017-01-16 33,212 mWh 42,157 mWh
2017-01-17 33,212 mWh 42,157 mWh
2017-01-18 33,212 mWh 42,157 mWh
2017-01-19 33,212 mWh 42,157 mWh
2017-01-20 33,212 mWh 42,157 mWh
2017-01-21 33,212 mWh 42,157 mWh
Battery life estimates
Battery life estimates based on observed drains
2017-01-14 - - - -
2017-01-15 - - - -
2017-01-16 - - - -
2017-01-17 - - - -
2017-01-18 - - - -
2017-01-19 - - - -
2017-01-20 - - - -
2017-01-21 - - - -
Current estimate of battery life based on all observed drains since OS install
Since OS install - - - -
    2017-02-16T19:00:59+00:00
    Steps in our Surface battery won’t charge article can help you identify and fix the problem, if you have issues with charging your Surface, you get a low-battery error, or your Surface turns off when you unplug it.
    Let's also ensure that the device is up to date by downloading and installing the latest Surface driver and firmware updates from the Microsoft Download Center. Look for the Windows 10 or Windows 8 .msi file.
    You can contact our supportteam if you need further assistance.
    *Re-posting to the right thread.
    2017-02-16T19:08:47+00:00
    Our drivers are updated, all the latest patches are installed.
    The problem is that the issued FIXES DO NOT WORK.
    The FIRMWARE HAS ISSUES.
    Please contact the appropriate folks at MS to get a resolution that works. READ THIS FORUM and you will see how many very competent folks have the SAME PROBLEM and MS is just ignoring us!
    2017-02-16T19:16:58+00:00
    I first tried the Windows 8 because I figured the old drivers worked, but alas, no charging.
    I then tried the 10, also, no charging.
    On both I monitored the battery before and after updating all windows updates (that the system was able to install)
    Currently there is a firmware that will not install because I need a 40% charge, but my system will not recognize a battery, or say 100% charged no battery detected, or sometimes it says 0% and not charging.
    I am repeating redundant information because it appears you did not read the entire thread.  The article does not fix our problems.
    And again, I would be happy to send my SP3 in for a "$200 out of warranty" battery replacement like was stated in Reddit by the Surface team when SP3 was being released and hyped.  But im not going to pay $450 (nearly 1/3 of the cost of the device) because the battery failed.
    Fun fact: My Surface RT VERSION 1 battery is still in excellent condition. Just had to replace the kickstand cause my children use it and its pretty beat up.  However my SP3 in pristine condition cannot run without the plug in.
    2017-02-16T19:17:17+00:00
    Bad news for all of ya:
    Once firmware is changed, there is no going back.
    So, until Microsoft can figure out ho to change how the battery reports, this will not get fixed.  They CAN'T fix it.
    They can only replace the devices with known good ones, and they aren't about to do that.  I have had two replacements sent to me, and both had the battery issue.  I'm assuming refurbs since the Pro 3 isn't even going to be produced anymore. (another clue they aren't planning on fixing this)
    They are going to charge us to replace them.. they are going to charge us to even TALK to them about it.
    @ Jestoni Mac:  The support team?  HA! Nice one...
    They told me four hours wasn't bad for battery life.  Then told me to run updates and let it go for a few days.  Like I haven't done that 5,000 times already.
    Face it people, MS doesn't care.  They know we will just buy the 4.. hopefully the 5 (I actually read a woman's post stating "Luckily, I was able to upgrade to the Pro 4 for yada yada yada.."  YOU FOOL!!!!!!
    Look at their changed in Office licensing and how they are making it such a pain in the butt in hopes of getting a subscription for Office 365 out of us.  I've said it before, they are just a big, greedy bully.
    The new CEO could care less about the previous CEO's screw up and is too busy with buying companies that could pose a threat in any way... and the shiny new Surface Pro 5.
    Pushing us into giving them more money.
    Why do we put up with it?
    I'm fine with almost ANY other tablet at this point, and I can use OpenOffice.
    2017-02-16T19:18:25+00:00
    Hey, one more thing: I have offered before to send you my SP3 if you would like a problem unit to study.  No strings attached. It would just be nice to see someone treating us and this issue with respect.
