Also just adding myself to this long list of SP3 LGC problems, for what it's worth. My problem started 12/7 with me being unable to turn on my SP3. I plugged it in to the charger, get the "plugged in, not charging", and stuck at 87%. It turns off if unplugged. I had all the current windows updates prior to the problem, including the Aug 29 and Nov 7 updates. I reinstalled the battery driver, and even did a full reset on the computer with no resolve.
Plugged in, not charging and if I unplug that AC adapter, it turns off
I have a Surface Pro that is a little over 2 years old. About two weeks ago, the battery now reports "Plugged in, not charging" and seems stuck at 60%. I say seemed because if I unplug that AC adapter, it dies instantly. It also will die periodically while on the charger. I have two Microsoft AC adapters and neither of them seem to charge my device.
I've tried all the Microsoft suggestions for this state, but none of them made any difference. Is there a way to diagnose if this is a hardware problem, or is this a new artifact from the latest updates? (My device reports it is up to date.) I never had any battery issues before (lucky, I suppose), and I've treated my surface pretty carefully. I'll be more than disappointed if it's crapped out already.
I'll attach a battery report, but I don't think it tells me anything in particular.
Battery report
| COMPUTER NAME | ORION |
| SYSTEM PRODUCT NAME | Microsoft Corporation Surface Pro 3 |
| BIOS | 3.11.1550 06/30/2016 |
| OS BUILD | 14393.693.amd64fre.rs1_release.161220-1747 |
| PLATFORM ROLE | Slate |
| CONNECTED STANDBY | Supported |
| REPORT TIME | 2017-01-22 19:53:16 |
Installed batteries
Information about each currently installed battery
| NAME | X898289 |
| MANUFACTURER | SIMPLO |
| SERIAL NUMBER | 1164122628 |
| CHEMISTRY | LION |
| DESIGN CAPACITY | 42,157 mWh |
| FULL CHARGE CAPACITY | 33,212 mWh |
| CYCLE COUNT | 310 |
Recent usage
Power states over the last 3 days
| 2017-01-20 09:41:00 | Active | AC | 60 % | 19,851 mWh |
| 09:44:00 | Battery changed | AC | - | - |
| 09:44:00 | Suspended | - | - | |
| 09:45:28 | Battery changed | AC | 60 % | 19,851 mWh |
| 09:45:28 | Active | AC | 60 % | 19,851 mWh |
| 09:45:48 | Connected standby | AC | 60 % | 19,851 mWh |
| 09:45:49 | Suspended | 60 % | 19,851 mWh | |
| 09:46:25 | Connected standby | AC | 59 % | 19,494 mWh |
| 09:46:25 | Active | AC | 59 % | 19,494 mWh |
| 2017-01-22 19:38:00 | Suspended | 59 % | 19,494 mWh | |
| 19:38:45 | Active | AC | 59 % | 19,494 mWh |
| 19:50:00 | Report generated | AC | 59 % | 19,494 mWh |
Battery usage
Battery drains over the last 3 days
Usage history
History of system usage on AC and battery
| 2017-01-14 | - | - | 4:18:11 | - | |
| 2017-01-15 | - | - | 23:59:59 | - | |
| 2017-01-16 | - | - | 23:59:59 | - | |
| 2017-01-17 | - | - | 23:59:59 | - | |
| 2017-01-18 | - | - | 23:59:59 | - | |
| 2017-01-19 | - | - | 23:59:59 | - | |
| 2017-01-20 | - | - | 23:57:53 | - | |
| 2017-01-21 | - | - | 23:59:59 | - |
Battery capacity history
Charge capacity history of the system's batteries
| 2017-01-14 | 33,212 mWh | 42,157 mWh |
| 2017-01-15 | 33,212 mWh | 42,157 mWh |
| 2017-01-16 | 33,212 mWh | 42,157 mWh |
| 2017-01-17 | 33,212 mWh | 42,157 mWh |
| 2017-01-18 | 33,212 mWh | 42,157 mWh |
| 2017-01-19 | 33,212 mWh | 42,157 mWh |
| 2017-01-20 | 33,212 mWh | 42,157 mWh |
| 2017-01-21 | 33,212 mWh | 42,157 mWh |
Battery life estimates
Battery life estimates based on observed drains
| 2017-01-14 | - | - | - | - | |
| 2017-01-15 | - | - | - | - | |
| 2017-01-16 | - | - | - | - | |
| 2017-01-17 | - | - | - | - | |
| 2017-01-18 | - | - | - | - | |
| 2017-01-19 | - | - | - | - | |
| 2017-01-20 | - | - | - | - | |
| 2017-01-21 | - | - | - | - |
Current estimate of battery life based on all observed drains since OS install
| Since OS install | - | - | - | - |
2016-12-08T16:24:36+00:00 -
Deleted
2016-12-14T04:14:53+00:00 I just tweeted this to Microsoft and Surface Support:
@microsoft @SurfaceSupport, please stop ignoring #SurfaceGate and fix our Surface Pro 3 bad battery firmware! http://bit.ly/2gGvCMw
#SurfaceGate seems rather fitting. Please, if you tweet or use Social Media, use the hashtag and let's get this the attention the issue deserves!
2016-12-15T01:23:47+00:00 I personally have an LGC that reports actual battery capacity larger than design capacity.
Same issue on my Surface Pro 3 with LGC battery:
Battery report
COMPUTER NAME ANDREJ-SURFACE SYSTEM PRODUCT NAME Microsoft Corporation Surface Pro 3 BIOS 3.11.1550 06/30/2016 OS BUILD 14965.1001.amd64fre.rs_prerelease.161104-1700 PLATFORM ROLE Slate CONNECTED STANDBY Supported REPORT TIME 2016-12-14 21:26:42 Installed batteries
NAME X883815 MANUFACTURER LGC-LGC SERIAL NUMBER 1159010564 CHEMISTRY LION DESIGN CAPACITY 42,157 mWh FULL CHARGE CAPACITY 44,270 mWh CYCLE COUNT 997 Is there a fix for that?
Barb Bowman 80,805 Reputation points MVP Volunteer Moderator2016-12-15T09:56:32+00:00 I have the same issue and cannot get an answer.
