It might be worthwhile trying to get it some press focus.
Reputational and flow-on commercial damage might get some action.
I have a Surface Pro that is a little over 2 years old. About two weeks ago, the battery now reports "Plugged in, not charging" and seems stuck at 60%. I say seemed because if I unplug that AC adapter, it dies instantly. It also will die periodically while on the charger. I have two Microsoft AC adapters and neither of them seem to charge my device.
I've tried all the Microsoft suggestions for this state, but none of them made any difference. Is there a way to diagnose if this is a hardware problem, or is this a new artifact from the latest updates? (My device reports it is up to date.) I never had any battery issues before (lucky, I suppose), and I've treated my surface pretty carefully. I'll be more than disappointed if it's crapped out already.
I'll attach a battery report, but I don't think it tells me anything in particular.
Battery report
| COMPUTER NAME | ORION |
| SYSTEM PRODUCT NAME | Microsoft Corporation Surface Pro 3 |
| BIOS | 3.11.1550 06/30/2016 |
| OS BUILD | 14393.693.amd64fre.rs1_release.161220-1747 |
| PLATFORM ROLE | Slate |
| CONNECTED STANDBY | Supported |
| REPORT TIME | 2017-01-22 19:53:16 |
Installed batteries
Information about each currently installed battery
| NAME | X898289 |
| MANUFACTURER | SIMPLO |
| SERIAL NUMBER | 1164122628 |
| CHEMISTRY | LION |
| DESIGN CAPACITY | 42,157 mWh |
| FULL CHARGE CAPACITY | 33,212 mWh |
| CYCLE COUNT | 310 |
Recent usage
Power states over the last 3 days
| 2017-01-20 09:41:00 | Active | AC | 60 % | 19,851 mWh |
| 09:44:00 | Battery changed | AC | - | - |
| 09:44:00 | Suspended | - | - | |
| 09:45:28 | Battery changed | AC | 60 % | 19,851 mWh |
| 09:45:28 | Active | AC | 60 % | 19,851 mWh |
| 09:45:48 | Connected standby | AC | 60 % | 19,851 mWh |
| 09:45:49 | Suspended | 60 % | 19,851 mWh | |
| 09:46:25 | Connected standby | AC | 59 % | 19,494 mWh |
| 09:46:25 | Active | AC | 59 % | 19,494 mWh |
| 2017-01-22 19:38:00 | Suspended | 59 % | 19,494 mWh | |
| 19:38:45 | Active | AC | 59 % | 19,494 mWh |
| 19:50:00 | Report generated | AC | 59 % | 19,494 mWh |
Battery usage
Battery drains over the last 3 days
Usage history
History of system usage on AC and battery
| 2017-01-14 | - | - | 4:18:11 | - | |
| 2017-01-15 | - | - | 23:59:59 | - | |
| 2017-01-16 | - | - | 23:59:59 | - | |
| 2017-01-17 | - | - | 23:59:59 | - | |
| 2017-01-18 | - | - | 23:59:59 | - | |
| 2017-01-19 | - | - | 23:59:59 | - | |
| 2017-01-20 | - | - | 23:57:53 | - | |
| 2017-01-21 | - | - | 23:59:59 | - |
Battery capacity history
Charge capacity history of the system's batteries
| 2017-01-14 | 33,212 mWh | 42,157 mWh |
| 2017-01-15 | 33,212 mWh | 42,157 mWh |
| 2017-01-16 | 33,212 mWh | 42,157 mWh |
| 2017-01-17 | 33,212 mWh | 42,157 mWh |
| 2017-01-18 | 33,212 mWh | 42,157 mWh |
| 2017-01-19 | 33,212 mWh | 42,157 mWh |
| 2017-01-20 | 33,212 mWh | 42,157 mWh |
| 2017-01-21 | 33,212 mWh | 42,157 mWh |
Battery life estimates
Battery life estimates based on observed drains
| 2017-01-14 | - | - | - | - | |
| 2017-01-15 | - | - | - | - | |
| 2017-01-16 | - | - | - | - | |
| 2017-01-17 | - | - | - | - | |
| 2017-01-18 | - | - | - | - | |
| 2017-01-19 | - | - | - | - | |
| 2017-01-20 | - | - | - | - | |
| 2017-01-21 | - | - | - | - |
Current estimate of battery life based on all observed drains since OS install
| Since OS install | - | - | - | - |
It actually has had press coverage, if you search on this you'll see there have been articles written about this.
Split from this thread.
Updated to 11/07/2016 firmware. Same problem persists. Battery 46% plugged in not charging. Device immediately turns off after removing charger.
To be more helpful to the people trying to fix this firmware.
Recent usage
| 2016-11-10 19:19:00 | Suspended | 58 % | 23,636 mWh | |
| 19:20:44 | Active | AC | 58 % | 23,628 mWh |
| 22:57:00 | Suspended | 58 % | 23,628 mWh | |
| 22:59:06 | Active | AC | 58 % | 23,606 mWh |
| 23:51:59 | Suspended | 58 % | 23,606 mWh | |
| 23:56:11 | Active | AC | 58 % | 23,598 mWh |
| 23:56:11 | Suspended | 58 % | 23,598 mWh | |
| 23:57:32 | Active | AC | 58 % | 23,598 mWh |
| 23:57:32 | Suspended | 58 % | 23,598 mWh | |
| 2016-11-11 00:02:02 | Active | AC | 58 % | 23,598 mWh |
| 00:02:02 | Suspended | 58 % | 23,598 mWh | |
| 00:03:38 | Active | AC | 58 % | 23,598 mWh |
| 00:13:14 | Connected standby | AC | 58 % | 23,598 mWh |
| 00:13:15 | Suspended | 58 % | 23,598 mWh | |
| 08:29:01 | Connected standby | AC | 58 % | 23,537 mWh |
| 08:29:01 | Suspended | 58 % | 23,537 mWh | |
| 10:04:44 | Active | AC | 58 % | 23,530 mWh |
| 14:36:57 | Connected standby | AC | 58 % | 23,492 mWh |
| 14:36:58 | Suspended | 58 % | 23,492 mWh | |
| 14:37:40 | Connected standby | AC | 58 % | 23,492 mWh |
| 14:37:40 | Active | AC | 58 % | 23,492 mWh |
| 15:51:55 | Connected standby | AC | 58 % | 23,484 mWh |
| 15:51:56 | Suspended | 58 % | 23,484 mWh | |
| 15:52:40 | Connected standby | AC | 58 % | 23,476 mWh |
| 15:52:40 | Active | AC | 58 % | 23,476 mWh |
| 2016-11-12 01:24:03 | Suspended | 58 % | 23,476 mWh | |
| 01:28:20 | Active | AC | 58 % | 23,476 mWh |
| 01:28:20 | Suspended | 58 % | 23,476 mWh | |
| 01:30:44 | Active | AC | 58 % | 23,476 mWh |
| 01:30:44 | Suspended | 58 % | 23,476 mWh | |
| 01:31:49 | Active | AC | 58 % | 23,476 mWh |
| 01:31:49 | Suspended | 58 % | 23,476 mWh | |
| 01:32:59 | Active | AC | 58 % | 23,476 mWh |
| 01:32:59 | Report generated | AC | 58 % | 23,476 mWh |
Before the update the firmware i couldnt see any mWh. Now the system can see the battery report but wont charge the battery. If i unplug the tablet the device shuts straight down. However now the device slowly loses charge. I have restarted my device 6 times after the firmware update, left on charge overnight but no luck with a working battery.
For some reason the firmware installed twice (last night and 10 minutes ago).
I just wanted to chime in here. On my Surface Pro 3, Windows shows a battery level of 100% and says that it's plugged in but not charging. As soon as I unplug the charger, it shuts off and will not turn back on until I plug in the charger again. I took it to the Microsoft Store and they said my only option was to pay $450 to replace it.
Every time I reboot it attempts to install the firmware update, but it always fails. I assume it's because the battery will not charge to 40%.
This is not okay, Microsoft.
