| Update for Surface Pro 3<br> <br><br> <br><br>Here is the summary of the update we’ve made in November for Surface Pro 3 devices:<br> <br><br><br> | • | Corrected a condition that causes the full charge capacity of the battery to be misreported to the operating system and device firmware<br> on some devices. | <br> | --- | --- | <br><br>Note: Before installing this update, ensure that the<br> Surface Pro 3 is plugged directly into AC power using the standard AC power adapter (do not use the Surface Docking Station), disconnect any USB devices or external monitors, and check that Windows shows a 40% charge or greater when you hover over the icon<br> in the taskbar before beginning. <br><br> <br><br>When you view the update history, this update will be listed as: <br><br><br> | • | System Firmware Update – 11/7/2016 | <br> | --- | --- | <br><br>The next ZIP and MSI files available on the Download Center will contain these drivers and any other updates that are released within the<br> next few weeks. Check the Surface IT Pro blog frequently for links to the following updates. We’ll also send an email when the MSI and ZIP files are available for download.<br> <br><br> <br><br>Windows 10 & Windows 8.1<br> <br><br> <br><br> | • | Surface Pro Embedded Controller Firmware (v38.11.50.0) corrects an error that may occur on a limited number of Surface Pro 3 devices where<br> the full charge capacity of the battery is misreported to the operating system and device firmware. This update corrects the firmware component that functions as the “fuel gauge” so that the battery capacity is accurately reported. See the<br>Surface Pro 3 Battery FAQ for more information. | <br> | --- | --- |
Plugged in, not charging and if I unplug that AC adapter, it turns off
I have a Surface Pro that is a little over 2 years old. About two weeks ago, the battery now reports "Plugged in, not charging" and seems stuck at 60%. I say seemed because if I unplug that AC adapter, it dies instantly. It also will die periodically while on the charger. I have two Microsoft AC adapters and neither of them seem to charge my device.
I've tried all the Microsoft suggestions for this state, but none of them made any difference. Is there a way to diagnose if this is a hardware problem, or is this a new artifact from the latest updates? (My device reports it is up to date.) I never had any battery issues before (lucky, I suppose), and I've treated my surface pretty carefully. I'll be more than disappointed if it's crapped out already.
I'll attach a battery report, but I don't think it tells me anything in particular.
Battery report
| COMPUTER NAME | ORION |
| SYSTEM PRODUCT NAME | Microsoft Corporation Surface Pro 3 |
| BIOS | 3.11.1550 06/30/2016 |
| OS BUILD | 14393.693.amd64fre.rs1_release.161220-1747 |
| PLATFORM ROLE | Slate |
| CONNECTED STANDBY | Supported |
| REPORT TIME | 2017-01-22 19:53:16 |
Installed batteries
Information about each currently installed battery
| NAME | X898289 |
| MANUFACTURER | SIMPLO |
| SERIAL NUMBER | 1164122628 |
| CHEMISTRY | LION |
| DESIGN CAPACITY | 42,157 mWh |
| FULL CHARGE CAPACITY | 33,212 mWh |
| CYCLE COUNT | 310 |
Recent usage
Power states over the last 3 days
| 2017-01-20 09:41:00 | Active | AC | 60 % | 19,851 mWh |
| 09:44:00 | Battery changed | AC | - | - |
| 09:44:00 | Suspended | - | - | |
| 09:45:28 | Battery changed | AC | 60 % | 19,851 mWh |
| 09:45:28 | Active | AC | 60 % | 19,851 mWh |
| 09:45:48 | Connected standby | AC | 60 % | 19,851 mWh |
| 09:45:49 | Suspended | 60 % | 19,851 mWh | |
| 09:46:25 | Connected standby | AC | 59 % | 19,494 mWh |
| 09:46:25 | Active | AC | 59 % | 19,494 mWh |
| 2017-01-22 19:38:00 | Suspended | 59 % | 19,494 mWh | |
| 19:38:45 | Active | AC | 59 % | 19,494 mWh |
| 19:50:00 | Report generated | AC | 59 % | 19,494 mWh |
Battery usage
Battery drains over the last 3 days
Usage history
History of system usage on AC and battery
| 2017-01-14 | - | - | 4:18:11 | - | |
| 2017-01-15 | - | - | 23:59:59 | - | |
| 2017-01-16 | - | - | 23:59:59 | - | |
| 2017-01-17 | - | - | 23:59:59 | - | |
| 2017-01-18 | - | - | 23:59:59 | - | |
| 2017-01-19 | - | - | 23:59:59 | - | |
| 2017-01-20 | - | - | 23:57:53 | - | |
| 2017-01-21 | - | - | 23:59:59 | - |
Battery capacity history
Charge capacity history of the system's batteries
| 2017-01-14 | 33,212 mWh | 42,157 mWh |
| 2017-01-15 | 33,212 mWh | 42,157 mWh |
| 2017-01-16 | 33,212 mWh | 42,157 mWh |
| 2017-01-17 | 33,212 mWh | 42,157 mWh |
| 2017-01-18 | 33,212 mWh | 42,157 mWh |
| 2017-01-19 | 33,212 mWh | 42,157 mWh |
| 2017-01-20 | 33,212 mWh | 42,157 mWh |
| 2017-01-21 | 33,212 mWh | 42,157 mWh |
Battery life estimates
Battery life estimates based on observed drains
| 2017-01-14 | - | - | - | - | |
| 2017-01-15 | - | - | - | - | |
| 2017-01-16 | - | - | - | - | |
| 2017-01-17 | - | - | - | - | |
| 2017-01-18 | - | - | - | - | |
| 2017-01-19 | - | - | - | - | |
| 2017-01-20 | - | - | - | - | |
| 2017-01-21 | - | - | - | - |
Current estimate of battery life based on all observed drains since OS install
| Since OS install | - | - | - | - |
Barb Bowman 80,805 Reputation points MVP Volunteer Moderator2016-11-09T09:49:14+00:00 -
Barb Bowman 80,805 Reputation points MVP Volunteer Moderator2016-11-09T10:55:38+00:00 See the post I made
Greg posted an abbreviated version. There have been multiple issues reported in
this thread and others and this update was documented to fix specifically:
"Windows 10 & Windows 8.1
• Surface Pro Embedded Controller Firmware (v38.11.50.0) corrects an
error that may occur on a limited number of Surface Pro 3 devices where the full
>>So this firmware update did nothing for me.
2016-11-09T11:31:30+00:00 Well, here's me just piling on I guess. The update installed, uninterrupted as far as I could tell. It took several automatic reboots to do so.
And now, it appears that I have no battery.
So, what's the next move?
It's almost a sad form of acceptance, I haven't used my SP3 in weeks, it just sits there with the power cord plugged in doing nothing. I've been looking at alternatives, like the Yoga, just having trouble justifying the spend. If this SP3 had a better power connection where a slight movement wouldn't cut the power it could be at the very least usable albeit anchored.
For good measure, here's my battery report.
Battery report
COMPUTER NAME MYSP3 SYSTEM PRODUCT NAME Microsoft Corporation Surface Pro 3 BIOS 3.11.1550 06/30/2016 OS BUILD 14393.351.amd64fre.rs1_release_inmarket.161014-1755 PLATFORM ROLE Slate CONNECTED STANDBY Supported REPORT TIME 2016-11-09 06:11:22 Installed batteries
NAME - MANUFACTURER - SERIAL NUMBER - CHEMISTRY - DESIGN CAPACITY - FULL CHARGE CAPACITY - CYCLE COUNT - Recent usage
2016-11-09 05:58:00 Suspended - - 06:02:43 Active AC - - 06:02:43 Suspended - - 06:08:18 Active AC - - 06:08:18 Report generated AC - - Battery usage
- - - - - Usage history
2016-08-30 - 2016-09-06 - - 66:45:04 19:34:20 2016-09-06 - 2016-09-13 - - 158:07:19 8:57:23 2016-09-13 - 2016-09-20 - - 48:59:18 45:38:43 2016-09-20 - 2016-09-27 - - 167:59:59 - 2016-09-27 - 2016-10-04 - - 125:42:36 70:59:16 2016-10-04 - 2016-10-11 - - 44:14:11 73:32:23 2016-10-11 - 2016-10-18 - - 109:47:54 56:22:47 2016-10-18 - 2016-10-25 - - 51:52:18 38:09:39 2016-10-25 - 2016-11-01 - - 90:42:47 77:05:20 2016-11-01 - - 23:59:59 - 2016-11-02 - - 23:59:59 - 2016-11-03 - - 23:59:59 - 2016-11-04 - - 23:59:59 - 2016-11-05 - - 23:59:59 - 2016-11-06 - 2016-11-06 - - 24:59:59 - 2016-11-07 - - 23:59:59 - 2016-11-08 - - 23:59:59 - Battery capacity history
2016-08-30 - 2016-09-06 39,611 mWh 42,157 mWh 2016-09-06 - 2016-09-13 39,611 mWh 42,157 mWh 2016-09-13 - 2016-09-20 39,611 mWh 42,157 mWh 2016-09-20 - 2016-09-27 39,611 mWh 42,157 mWh 2016-09-27 - 2016-10-04 39,611 mWh 42,157 mWh 2016-10-04 - 2016-10-11 39,611 mWh 42,157 mWh 2016-10-11 - 2016-10-18 39,611 mWh 42,157 mWh 2016-10-18 - 2016-10-25 39,611 mWh 42,157 mWh 2016-10-25 - 2016-11-01 23,022 mWh 24,502 mWh 2016-11-01 - - 2016-11-02 - - 2016-11-03 - - 2016-11-04 - - 2016-11-05 - - 2016-11-06 - 2016-11-06 - - 2016-11-07 - - 2016-11-08 - - Battery life estimates
2016-08-30 - 2016-09-06 - - - - 2016-09-06 - 2016-09-13 - - - - 2016-09-13 - 2016-09-20 - - - - 2016-09-20 - 2016-09-27 - - - - 2016-09-27 - 2016-10-04 - - - - 2016-10-04 - 2016-10-11 - - - - 2016-10-11 - 2016-10-18 - - - - 2016-10-18 - 2016-10-25 - - - - 2016-10-25 - 2016-11-01 - - - - 2016-11-01 - - - - 2016-11-02 - - - - 2016-11-03 - - - - 2016-11-04 - - - - 2016-11-05 - - - - 2016-11-06 - 2016-11-06 - - - - 2016-11-07 - - - - 2016-11-08 - - - - Current estimate of battery life based on all observed drains since OS install
Since OS install - - - - -
2016-11-09T15:39:18+00:00 I have the same as you 100% fully charged when i click on the battery icon
except I have 3 different random battery messages when i hover over the battery icon every time i reboot
and also I cant get the update to install it gets to about 90% then gives up
0% plugged in not charging
no battery detected
2016-11-09T22:05:25+00:00 Hello Barb,
I use my SP3 in a dock during the day at my office. The November 7 update installed while the SP3 was docked.
How can undo the firmware update so that I can re-apply the update according to the (apparently important) instruction:
Note: Before installing this update, ensure that the Surface Pro 3 is plugged directly into AC power using the standard AC power adapter (do not use the Surface Docking Station), disconnect any USB devices or external monitors, and check that Windows shows a 40% charge or greater when you hover over the icon in the taskbar before beginning.
I note on this page https://www.microsoft.com/surface/en-au/support/install-update-activate/pro-3-update-history?os=windows-10&=undefined that:
- Firmware updates cannot be uninstalled or reverted to an earlier version.
I would have thought that if the update had a prerequisite like being plugged in to AC power only, that it would check that condition before running. Especially if it can't be undone!
LBofS
