Plugged in, not charging and if I unplug that AC adapter, it turns off
2017-01-23T01:46:36+00:00
I have a Surface Pro that is a little over 2 years old. About two weeks ago, the battery now reports "Plugged in, not charging" and seems stuck at 60%. I say seemed because if I unplug that AC adapter, it dies instantly. It also will die periodically while on the charger. I have two Microsoft AC adapters and neither of them seem to charge my device.
I've tried all the Microsoft suggestions for this state, but none of them made any difference. Is there a way to diagnose if this is a hardware problem, or is this a new artifact from the latest updates? (My device reports it is up to date.) I never had any battery issues before (lucky, I suppose), and I've treated my surface pretty carefully. I'll be more than disappointed if it's crapped out already.
I'll attach a battery report, but I don't think it tells me anything in particular.
Battery report
COMPUTER NAME ORION
SYSTEM PRODUCT NAME Microsoft Corporation Surface Pro 3
BIOS 3.11.1550 06/30/2016
OS BUILD 14393.693.amd64fre.rs1_release.161220-1747
PLATFORM ROLE Slate
CONNECTED STANDBY Supported
REPORT TIME 2017-01-22 19:53:16
Installed batteries
Information about each currently installed battery
NAME X898289
MANUFACTURER SIMPLO
SERIAL NUMBER 1164122628
CHEMISTRY LION
DESIGN CAPACITY 42,157 mWh
FULL CHARGE CAPACITY 33,212 mWh
CYCLE COUNT 310
Recent usage
Power states over the last 3 days
2017-01-20 09:41:00 Active AC 60 % 19,851 mWh
09:44:00 Battery changed AC - -
09:44:00 Suspended - -
09:45:28 Battery changed AC 60 % 19,851 mWh
09:45:28 Active AC 60 % 19,851 mWh
09:45:48 Connected standby AC 60 % 19,851 mWh
09:45:49 Suspended 60 % 19,851 mWh
09:46:25 Connected standby AC 59 % 19,494 mWh
09:46:25 Active AC 59 % 19,494 mWh
2017-01-22 19:38:00 Suspended 59 % 19,494 mWh
19:38:45 Active AC 59 % 19,494 mWh
19:50:00 Report generated AC 59 % 19,494 mWh
Battery usage
Battery drains over the last 3 days
Usage history
History of system usage on AC and battery
2017-01-14 - - 4:18:11 -
2017-01-15 - - 23:59:59 -
2017-01-16 - - 23:59:59 -
2017-01-17 - - 23:59:59 -
2017-01-18 - - 23:59:59 -
2017-01-19 - - 23:59:59 -
2017-01-20 - - 23:57:53 -
2017-01-21 - - 23:59:59 -
Battery capacity history
Charge capacity history of the system's batteries
2017-01-14 33,212 mWh 42,157 mWh
2017-01-15 33,212 mWh 42,157 mWh
2017-01-16 33,212 mWh 42,157 mWh
2017-01-17 33,212 mWh 42,157 mWh
2017-01-18 33,212 mWh 42,157 mWh
2017-01-19 33,212 mWh 42,157 mWh
2017-01-20 33,212 mWh 42,157 mWh
2017-01-21 33,212 mWh 42,157 mWh
Battery life estimates
Battery life estimates based on observed drains
2017-01-14 - - - -
2017-01-15 - - - -
2017-01-16 - - - -
2017-01-17 - - - -
2017-01-18 - - - -
2017-01-19 - - - -
2017-01-20 - - - -
2017-01-21 - - - -
Current estimate of battery life based on all observed drains since OS install
Since OS install - - - -
    2016-10-13T04:19:59+00:00
    My SFP 3 currently in the same state as your. The battery voltage drops below 5.8v (i.e. 2.9v for each cell) and the protection circuit in battery controller cut off connection, that's why sometimes it shows battery not detected.
    Since some circuits still use battery current when the Surface is turned on using AC adapter, I would recommend you do not turn on the tablet, otherwise the battery voltage may go to very low and the battery itself will be dead completely within a few weeks.
    Regarding this issue with battery voltage, I have two question:
    • Is there anyone who use Power Cover with bad SFP3? If yes, how is fluctuated the voltage of internal battery (indicated by some third party software, such as Hardware Info (www.hwinfo.com)?
    • Microsoft, please, issue some raw firmware that help charge battery at least once, otherwise it is dying because of low voltage.
    2016-10-13T18:08:37+00:00
    Barb,
    This is what I'm talking about.  many users frustrated with no action from MS, to the point of leaving the product.  This is really a big issue that is just being sat on.
  3. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2016-10-14T10:39:02+00:00
    I am as frustrated as you are, I've begged for information and for updated
    information to be posted here, even a "we are still working on the issue", but
    the silence continues.
    2016-10-14T19:07:17+00:00
    Well I think we have waited long enough for some sort of acknowledgement of progress on this issue. It has almost been 2 months since i've had a usable device.
    I'm going to bite the bullet and look at a new laptop. Looks like this paperweight is going to sit on my shelf indefinitely, at least until MS decides to update us.
  5. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2016-10-14T19:13:51+00:00
