It could be because the dock doesn't provide as much power as the AC adapter alone, but i find this unlikely.
Plugged in, not charging and if I unplug that AC adapter, it turns off
I have a Surface Pro that is a little over 2 years old. About two weeks ago, the battery now reports "Plugged in, not charging" and seems stuck at 60%. I say seemed because if I unplug that AC adapter, it dies instantly. It also will die periodically while on the charger. I have two Microsoft AC adapters and neither of them seem to charge my device.
I've tried all the Microsoft suggestions for this state, but none of them made any difference. Is there a way to diagnose if this is a hardware problem, or is this a new artifact from the latest updates? (My device reports it is up to date.) I never had any battery issues before (lucky, I suppose), and I've treated my surface pretty carefully. I'll be more than disappointed if it's crapped out already.
I'll attach a battery report, but I don't think it tells me anything in particular.
Battery report
| COMPUTER NAME | ORION |
| SYSTEM PRODUCT NAME | Microsoft Corporation Surface Pro 3 |
| BIOS | 3.11.1550 06/30/2016 |
| OS BUILD | 14393.693.amd64fre.rs1_release.161220-1747 |
| PLATFORM ROLE | Slate |
| CONNECTED STANDBY | Supported |
| REPORT TIME | 2017-01-22 19:53:16 |
Installed batteries
Information about each currently installed battery
| NAME | X898289 |
| MANUFACTURER | SIMPLO |
| SERIAL NUMBER | 1164122628 |
| CHEMISTRY | LION |
| DESIGN CAPACITY | 42,157 mWh |
| FULL CHARGE CAPACITY | 33,212 mWh |
| CYCLE COUNT | 310 |
Recent usage
Power states over the last 3 days
| 2017-01-20 09:41:00 | Active | AC | 60 % | 19,851 mWh |
| 09:44:00 | Battery changed | AC | - | - |
| 09:44:00 | Suspended | - | - | |
| 09:45:28 | Battery changed | AC | 60 % | 19,851 mWh |
| 09:45:28 | Active | AC | 60 % | 19,851 mWh |
| 09:45:48 | Connected standby | AC | 60 % | 19,851 mWh |
| 09:45:49 | Suspended | 60 % | 19,851 mWh | |
| 09:46:25 | Connected standby | AC | 59 % | 19,494 mWh |
| 09:46:25 | Active | AC | 59 % | 19,494 mWh |
| 2017-01-22 19:38:00 | Suspended | 59 % | 19,494 mWh | |
| 19:38:45 | Active | AC | 59 % | 19,494 mWh |
| 19:50:00 | Report generated | AC | 59 % | 19,494 mWh |
Battery usage
Battery drains over the last 3 days
Usage history
History of system usage on AC and battery
| 2017-01-14 | - | - | 4:18:11 | - | |
| 2017-01-15 | - | - | 23:59:59 | - | |
| 2017-01-16 | - | - | 23:59:59 | - | |
| 2017-01-17 | - | - | 23:59:59 | - | |
| 2017-01-18 | - | - | 23:59:59 | - | |
| 2017-01-19 | - | - | 23:59:59 | - | |
| 2017-01-20 | - | - | 23:57:53 | - | |
| 2017-01-21 | - | - | 23:59:59 | - |
Battery capacity history
Charge capacity history of the system's batteries
| 2017-01-14 | 33,212 mWh | 42,157 mWh |
| 2017-01-15 | 33,212 mWh | 42,157 mWh |
| 2017-01-16 | 33,212 mWh | 42,157 mWh |
| 2017-01-17 | 33,212 mWh | 42,157 mWh |
| 2017-01-18 | 33,212 mWh | 42,157 mWh |
| 2017-01-19 | 33,212 mWh | 42,157 mWh |
| 2017-01-20 | 33,212 mWh | 42,157 mWh |
| 2017-01-21 | 33,212 mWh | 42,157 mWh |
Battery life estimates
Battery life estimates based on observed drains
| 2017-01-14 | - | - | - | - | |
| 2017-01-15 | - | - | - | - | |
| 2017-01-16 | - | - | - | - | |
| 2017-01-17 | - | - | - | - | |
| 2017-01-18 | - | - | - | - | |
| 2017-01-19 | - | - | - | - | |
| 2017-01-20 | - | - | - | - | |
| 2017-01-21 | - | - | - | - |
Current estimate of battery life based on all observed drains since OS install
| Since OS install | - | - | - | - |
2016-10-05T15:18:58+00:00 -
2016-10-05T15:21:37+00:00 Microsoft, we need an update on the root cause of this issue and the progress for a potential fix. We have been dealing with a $1000+ paper weight for over a month now.
Each passing day results in less and less confidence in your products. I was really considering a surface book purchase after my SP3 reaches EOL, but with support like this, I know that my money will be spent elsewhere
2016-10-06T17:48:19+00:00 I appear to be having the same problem with my SP3. Battery shows 63% available, not charging. Device turns off instantly upon unplugging. Battery report below (truncated due to space restrictions; can send full report if need be):
NAME X883815 MANUFACTURER LGC-LGC SERIAL NUMBER 1167006212 CHEMISTRY LION DESIGN CAPACITY 42,157 mWh FULL CHARGE CAPACITY 34,542 mWh CYCLE COUNT 411 Recent usage
2016-10-0500:05:33 Active AC 73 % 25,255 mWh 00:14:03 Active Battery 73 % 25,255 mWh 00:22:09 Connected standby Battery 69 % 23,894 mWh 03:14:11 Suspended 54 % 18,810 mWh 10:49:20 Connected standby Battery 53 % 18,453 mWh 10:49:20 Active Battery 53 % 18,453 mWh 11:12:22 Connected standby Battery 44 % 15,147 mWh 11:39:03 Suspended 41 % 14,326 mWh 13:09:16 Connected standby Battery 40 % 13,984 mWh 13:09:16 Active Battery 40 % 13,984 mWh 13:31:05 Active AC 29 % 10,085 mWh 13:32:56 Connected standby AC 30 % 10,366 mWh 14:34:37 Active AC 65 % 22,443 mWh 16:38:35 Active Battery 67 % 23,005 mWh 17:43:33 Active AC 41 % 14,030 mWh 17:59:46 Connected standby AC 52 % 18,035 mWh 18:00:31 Connected standby Battery 53 % 18,164 mWh 18:00:32 Active Battery 53 % 18,164 mWh 18:00:38 Connected standby Battery 53 % 18,172 mWh 18:00:38 Active Battery 53 % 18,172 mWh 18:00:43 Connected standby Battery 53 % 18,172 mWh 18:21:29 Suspended 50 % 17,427 mWh 2016-10-0609:45:28 Connected standby Battery 50 % 17,123 mWh 09:45:28 Active Battery 50 % 17,123 mWh 09:45:50 Active AC 49 % 17,016 mWh 09:49:03 Connected standby AC 51 % 17,723 mWh 10:32:52 Active AC 66 % 22,937 mWh 10:33:27 Connected standby AC 67 % 23,005 mWh 10:44:47 Active AC 67 % 23,150 mWh 11:22:00 Active Battery 66 % 22,967 mWh 11:44:15 Suspended 58 % 20,201 mWh 12:12:59 Active AC 63 % 21,668 mWh 13:20:00 Suspended 63 % 21,668 mWh 13:24:03 Active AC 63 % 21,668 mWh 13:40:00 Report generated AC 63 % 21,668 mWh -
2016-10-06T18:59:10+00:00 Two weeks ago I reported problems with LGC battery.
My wife has the Surface Pro 3 in a different state now,
so I can't check the battery report, but she tells me
that it started charging again yesterday! Don't know
if this is an outlier, or MSFT tried to slip a fix out, but
thought it was interesting that it would charge now....
In fact, it's back to normal, acts like a tablet when not
on the cord.....
2016-10-06T19:10:21+00:00 Lloyd! I hope that you are right. I will try an update a little later and report back as well.
Note: The official silence is still unacceptable even if the fix is in the wild.
