Surface Pro 3 LGC Battery Degradation
2017-02-16T00:04:44+00:00
Split from this thread.
It was suggested that I open a new thread for this issue that I am having.
Since the Win 10 Anniversary update, I was not able to turn on my Surface Pro 3 i7 512GB with LGC LGC Battery without having it plugged in with the power supply or docking (I own a total of Three Surface Pro 3 Docks at home and 2 offices). It always said "82%, Plugged in, Not Charging", and would always instantly turn off once I pulled off the power supply tab.
I had spoke with a Technical Agent online, had my Pro 3 remote accessed, did all the proposed solutions, and even had a call from Bellevue, WA (I live in Hong Kong) before I found out that it was a software issue as stated by Microsoft.
With Auto Update turned on, I was notified that I should restart my Pro 3 this morning while I was on the docking station. I was happy that this issue was going to be resolved, but now I am disappointed that this firmware update did nothing for my Pro 3.
I'm hoping that someone out there has some suggestions.
Thank You.
    2017-03-03T00:37:56+00:00
    I'm still disappointed that the Simplo guys are fine (colleague's Pro3 is fine), whereas us LG battery has our Pro3 utterly useless.
    I have the Simplo battery and my SP3 is not fine! My SP3 is almost 100% dead. It will not stay powered on even with the AC adapter plugged in (and I've tried multiple adapters). It powers on for a short time, then dies without warning.  Tried all MS "suggestions" and nothing changed. I'm so embarrassed by this device because I've spent so much money for the i7 version and it lasted two years under very gentle use and now seems like complete garbage with no support from MS. The words "utter disappointment" now comes to mind every time someone mentions a Surface Pro to me!
    2017-03-29T18:38:54+00:00
    hello, i am having issues with my surface pro 3 life too, lasting only 1.5 hours
    here is my report file  :///C:/Users/luken/battery-report.html
    Battery report
    COMPUTER NAME DESKTOP-VBT8FQL
    SYSTEM PRODUCT NAME Microsoft Corporation Surface Pro 3
    BIOS 3.11.2050 11/11/2016
    OS BUILD 14393.953.amd64fre.rs1_release_inmarket.170303-1614
    PLATFORM ROLE Slate
    CONNECTED STANDBY Supported
    REPORT TIME 2017-03-29 14:30:21
    Installed batteries
    Information about each currently installed battery
    BATTERY 1
    NAME X883815
    MANUFACTURER LGC-LGC
    SERIAL NUMBER 1221403908
    CHEMISTRY LION
    DESIGN CAPACITY 42,157 mWh
    FULL CHARGE CAPACITY 40,713 mWh
    CYCLE COUNT 6
    Recent usage
    Power states over the last 3 days
    START TIME STATE SOURCE CAPACITY REMAINING
    2017-03-28 06:13:43 Active Battery 72 % 29,268 mWh
    06:15:01 Suspended 71 % 28,895 mWh
    06:16:14 Active Battery 71 % 28,530 mWh
    06:24:37 Connected standby Battery 66 % 26,494 mWh
    06:27:01 Active Battery 65 % 26,456 mWh
    06:32:26 Suspended 61 % 24,852 mWh
    06:33:28 Active Battery 61 % 24,556 mWh
    06:38:21 Connected standby Battery 56 % 22,640 mWh
    06:38:23 Suspended 56 % 22,640 mWh
    14:30:33 Active Battery 100 % 40,371 mWh
    14:40:49 Connected standby Battery 89 % 35,796 mWh
    14:46:12 Active Battery 88 % 35,591 mWh
    14:52:19 Connected standby Battery 82 % 32,992 mWh
    15:00:01 Active Battery 82 % 32,916 mWh
    16:00:01 Suspended 31 % 12,715 mWh
    16:01:51 Active Battery 30 % 12,259 mWh
    16:23:03 Connected standby Battery 7 % 2,888 mWh
    16:23:04 Suspended 7 % 2,888 mWh
    17:00:33 Active AC 6 % 2,508 mWh
    18:21:20 Active Battery 8 % 3,101 mWh
    18:21:37 Active AC 7 % 3,010 mWh
    18:39:27 Active Battery 7 % 2,698 mWh
    18:39:57 Active AC 6 % 2,546 mWh
    18:55:13 Connected standby AC 7 % 2,675 mWh
    18:55:46 Active AC 7 % 2,759 mWh
    19:07:53 Connected standby AC 8 % 3,200 mWh
    19:07:57 Connected standby Battery 8 % 3,207 mWh
    19:07:57 Active Battery 8 % 3,207 mWh
    19:08:03 Connected standby Battery 8 % 3,207 mWh
    19:11:50 Connected standby AC 8 % 3,146 mWh
    19:11:50 Active AC 8 % 3,146 mWh
    19:26:00 Suspended 9 % 3,504 mWh
    19:28:30 Active AC 9 % 3,792 mWh
    19:32:14 Connected standby AC 10 % 3,922 mWh
    19:40:48 Connected standby Battery 15 % 6,019 mWh
    19:40:49 Active Battery 15 % 6,019 mWh
    19:41:09 Active AC 15 % 6,019 mWh
    19:52:52 Connected standby AC 16 % 6,589 mWh
    19:52:54 Connected standby Battery 16 % 6,597 mWh
    19:52:54 Active Battery 16 % 6,597 mWh
    19:53:00 Connected standby Battery 16 % 6,597 mWh
    19:57:41 Connected standby AC 16 % 6,551 mWh
    19:57:41 Active AC 16 % 6,551 mWh
    19:57:47 Connected standby AC 16 % 6,566 mWh
    19:59:25 Active AC 18 % 7,098 mWh
    20:30:38 Active Battery 20 % 7,881 mWh
    20:30:41 Active AC 19 % 7,866 mWh
    21:03:23 Connected standby AC 25 % 10,184 mWh
    21:06:10 Active AC 26 % 10,640 mWh
    21:06:13 Connected standby AC 26 % 10,640 mWh
    21:12:45 Connected standby Battery 31 % 12,525 mWh
    21:12:46 Active Battery 31 % 12,525 mWh
    21:12:51 Connected standby Battery 31 % 12,525 mWh
    21:14:25 Connected standby AC 31 % 12,517 mWh
    21:14:26 Active AC 31 % 12,517 mWh
    21:32:38 Active Battery 33 % 13,368 mWh
    21:35:42 Connected standby Battery 31 % 12,358 mWh
    21:35:50 Active Battery 31 % 12,335 mWh
    21:36:20 Active AC 30 % 12,122 mWh
    21:52:44 Connected standby AC 28 % 11,126 mWh
    21:52:47 Active AC 28 % 11,126 mWh
    2017-03-29 02:26:43 Connected standby AC 36 % 14,721 mWh
    05:28:04 Active AC 101 % 40,607 mWh
    05:28:35 Connected standby AC 101 % 40,607 mWh
    05:52:12 Active AC 101 % 40,607 mWh
    05:52:43 Connected standby AC 101 % 40,607 mWh
    05:53:22 Active AC 101 % 40,607 mWh
    05:53:54 Connected standby AC 101 % 40,607 mWh
    05:57:11 Connected standby Battery 101 % 40,607 mWh
    05:57:11 Active Battery 101 % 40,607 mWh
    05:57:17 Connected standby Battery 101 % 40,607 mWh
    05:57:59 Active Battery 101 % 40,607 mWh
    05:58:00 Connected standby Battery 101 % 40,607 mWh
    05:59:15 Active Battery 101 % 40,607 mWh
    06:04:55 Active AC 95 % 38,433 mWh
    06:16:37 Connected standby AC 97 % 38,996 mWh
    06:25:33 Connected standby Battery 99 % 40,029 mWh
    06:25:33 Active Battery 99 % 40,029 mWh
    06:31:28 Connected standby Battery 96 % 38,638 mWh
    06:39:02 Active Battery 96 % 38,600 mWh
    07:26:22 Connected standby Battery 51 % 20,467 mWh
    07:26:23 Suspended 51 % 20,467 mWh
    14:28:56 Connected standby Battery 100 % 40,713 mWh
    14:28:56 Active Battery 100 % 40,713 mWh
    14:29:17 Connected standby Battery 100 % 40,713 mWh
    14:29:19 Active Battery 100 % 40,713 mWh
    14:29:19 Report generated Battery 100 % 40,713 mWh
    Battery usage
    Battery drains over the last 3 days
    START TIME STATE DURATION ENERGY DRAINED
    2017-03-28 06:13:43 Active 0:01:18 1 % 373 mWh
    06:16:14 Active 0:08:23 5 % 2,036 mWh
    06:24:37 Connected standby 0:02:23 - 38 mWh
    06:27:01 Active 0:05:25 4 % 1,604 mWh
    06:33:28 Active 0:04:52 5 % 1,916 mWh
    06:38:21 Connected standby 0:00:02 -
    14:30:33 Active 0:10:15 11 % 4,575 mWh
    14:40:49 Connected standby 0:05:22 1 % 205 mWh
    14:46:12 Active 0:06:07 6 % 2,599 mWh
    14:52:19 Connected standby 0:07:41 - 76 mWh
    15:00:01 Active 1:00:00 50 % 20,201 mWh
    16:01:51 Active 0:21:12 23 % 9,371 mWh
    16:23:03 Connected standby 0:00:00 -
    18:21:20 Active 0:00:16 - 91 mWh
    18:39:27 Active 0:00:29 - 152 mWh
    19:07:57 Connected standby 0:00:00 -
    19:07:57 Active 0:00:05 - -
    19:08:03 Connected standby 0:03:47 - 61 mWh
    19:40:48 Connected standby 0:00:00 -
    19:40:49 Active 0:00:20 - -
    19:52:54 Connected standby 0:00:00 -
    19:52:54 Active 0:00:05 - -
    19:53:00 Connected standby 0:04:41 - 46 mWh
    20:30:38 Active 0:00:02 - 15 mWh
    21:12:45 Connected standby 0:00:00 -
    21:12:46 Active 0:00:05 - -
    21:12:51 Connected standby 0:01:34 - 8 mWh
    21:32:38 Active 0:03:04 3 % 1,010 mWh
    21:35:42 Connected standby 0:00:07 - 23 mWh
    21:35:50 Active 0:00:30 1 % 213 mWh
    05:57:11 Connected standby 0:00:00 -
    05:57:11 Active 0:00:05 - -
    05:57:17 Connected standby 0:00:42 -
    05:57:59 Active 0:00:01 - -
    05:58:00 Connected standby 0:01:15 -
    05:59:15 Active 0:05:40 5 % 2,174 mWh
    06:25:33 Connected standby 0:00:00 -
    06:25:33 Active 0:05:55 3 % 1,391 mWh
    06:31:28 Connected standby 0:07:33 - 38 mWh
    06:39:02 Active 0:47:20 45 % 18,133 mWh
    07:26:22 Connected standby 0:00:00 -
    14:28:56 Connected standby 0:00:00 -
    14:28:56 Active 0:00:21 - -
    14:29:17 Connected standby 0:00:01 -
    14:29:19 Active 0:00:00 - -
    Usage history
    History of system usage on AC and battery
    BATTERY DURATION AC DURATION
    PERIOD ACTIVE CONNECTED STANDBY ACTIVE CONNECTED STANDBY
    Battery capacity history
    Charge capacity history of the system's batteries
    PERIOD FULL CHARGE CAPACITY DESIGN CAPACITY
    Battery life estimates
    Battery life estimates based on observed drains
    AT FULL CHARGE AT DESIGN CAPACITY
    Current estimate of battery life based on all observed drains since OS install
    Since OS install - - - -
    2017-03-29T21:07:14+00:00
    Hello Luke,
    Can you confirm if you followed these troubleshooting steps:
    • Uninstall then re-install the battery driver?
    • Did you check this link for battery issue?
    • Is your device has the latest updates installed?
    We'll be waiting for your reply.
    2017-04-07T00:38:25+00:00
    Hi Joseph,
    What is going on internally in MS regarding this issue? We have tried all of these "troubleshooting" steps to get our devices working. My paperweight of a device has been placed on a shelf since September of 2016 after a frustrating attempt to use my "ultraportable" device device tethered to the wall. Any slight movement against the power cord would turn the device off causing obvious data loss. Other users have suffered with this issue longer.
    We have waited long enough for a fix for this issue. Who can we escalate this issue to internally to get some sort of amicable resolution? It is quite pathetic that such an expensive device was barely put into use for 13 months before it catastrophically failed.
    We will not keep quiet about this issue until a resolution has been made. If no response is received here, or if my post is deleted, i will continue to pursue other avenues.
    This issue has persisted long enough and Microsoft has had ample time to seek a solution.
    2017-04-07T14:07:43+00:00
    Since you mentioned that you have already did all the troubleshooting steps provided, it would be best if you contact our Answer Desk team for further assistance.
    You can also check this link for more details for Surface Pro 3 Battery FAQs.
    Regards.
