Surface Pro 3 LGC Battery Degradation
2017-02-16T00:04:44+00:00
Split from this thread.
It was suggested that I open a new thread for this issue that I am having.
Since the Win 10 Anniversary update, I was not able to turn on my Surface Pro 3 i7 512GB with LGC LGC Battery without having it plugged in with the power supply or docking (I own a total of Three Surface Pro 3 Docks at home and 2 offices). It always said "82%, Plugged in, Not Charging", and would always instantly turn off once I pulled off the power supply tab.
I had spoke with a Technical Agent online, had my Pro 3 remote accessed, did all the proposed solutions, and even had a call from Bellevue, WA (I live in Hong Kong) before I found out that it was a software issue as stated by Microsoft.
With Auto Update turned on, I was notified that I should restart my Pro 3 this morning while I was on the docking station. I was happy that this issue was going to be resolved, but now I am disappointed that this firmware update did nothing for my Pro 3.
I'm hoping that someone out there has some suggestions.
Thank You.
  1. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2016-08-31T16:13:01+00:00
    Are you docked or undocked? If you unplug, does it shut down?
  2. Deleted
    2016-08-31T16:17:23+00:00
    same probleme, you'll make a fix?
    2016-08-31T16:46:20+00:00
    I contacted the live chat and I said That a second patch should arrive in a week
  5. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2016-08-31T17:55:30+00:00
    please post the chat transcript. this is not the case.
