Surface 3 charging issues
2015-05-06T14:21:00+00:00
I'm sure the Surface 2 and other models suffered from this problem...
After getting my Surface 3 yesterday, I plugged it in as it was delivered with about 24% batter life.  The little white light on the micro-USB charger than comes with the Surface lit up.  I assumed all was well, and started the Windows Updates.  It was taking a while so I left it and went to bed.
The next morning the Surface was off, and when I tried to switch it on the battery symbol appeared that indicates it had no juice.  It was still plugged in to the charger and the plug was still lit.
I removed it a couple of times and eventually it must have started to charge as it allowed me to boot, and I could see it was charging.
However, whenever I plug it into any other USB port to charge it (such as on my PC), I get the "Plugged in, not charging" message).
I suspect a faulty micro-USB connector (a poor replacement for the old magnetic ones), but wanted to see if anyone elese was having trouble with either the supplied charger or charging from other USB ports.
Surface | Other
2015-12-17T00:35:26+00:00
MA_905,
Thanks for the update and sorry for the delay in following up.
I am reaching out to find out if your issue is now resolved and if not, I would like for you to please give the two button shutdown a try.
Here’s how:
Step 1: Press and hold the power button on your Surface for 30 seconds and then release it.
Step 2: Press and hold the volume-up button and the power button at the same time for at least 15 seconds and then release both.        <br> <br><br>The screen may flash the Surface logo, but continue holding the buttons down for at least 15 seconds.
Step 4: Press and release the power button to turn your Surface back on.
 Once done, please proceed to fully charge the device and let us know your outcome.
2015-05-06T16:58:56+00:00
what's more likely is that the USB ports that you've used can't provide enough power to charge the device.
2015-07-22T16:55:03+00:00
On Wed, 22 Jul 2015 16:31:18 +0000, quadtek wrote:
>> This is a surface 3, not a pro3
take a look at
http://www.microsoft.com/surface/en-us/support/warranty-service-and-recovery/surface-wont-turn-on#shutdown
  • this applies to your Surface 3
Barb
Windows Experience MVP
2016-03-05T11:51:47+00:00
did you try the solutions at https://www.microsoft.com/surface/en-us/support/warranty-service-and-recovery/surface-wont-turn-on-battery-wont-charge?os=windows-10 ?
If yes, your best option is to go to a physical retail Microsoft Store if you are near one in the US, and if not near a store https://www.microsoft.com/surface/en-us/support/contact-us
2015-12-17T00:48:32+00:00
I contacted MS and they helped me in this one. I had to do a current update. when this did not fix it I had to a a factory reset. then do the update battery life is now as expected.
337 additional answers
    2016-04-25T17:44:59+00:00
    Thank you for all the suggestions.  I have never been able to repeat the condition where the Surface would not charge from its own charger that I experienced on the first day.  I wonder if perhaps all the WIndows updates I did (I think there were about 52 of them in all) included a battery charging issue fix that means that problem went away.
    I have yet to find a single USB source that can charge the Surface 3 other than the included adaptor.
    Can anyone tell me if they have had ANY luck at all charging it from a PC's USB port, for example?
    The micro-USB charging was touted as a bit of a covenience, but its not terrible convenient if it doesn't work on anything other than the bundled adaptor.
    I have read in many places that they claim it may charge slower, but my experience is that it will not charge at all.
    Is it supposed to be able to charge at all, say for example, from a 5W iPhone charger?
    The Surface charger is 13 Watts. It has output of 5.2V at 2.5A.
    This is quite a bit more than a standard cell phone premium charger which is 5V at 2.1A, which is 10.1W. (versus a standard, cheaper cell charger which can only output 1A)
    I was able to get my Surface 3 to charge from an aftermarket cellphone 2A charger, but the charger got EXTREMELY hot after a few minutes. Most cell phone chargers will not work for the Surface 3, and you run the risk of them catching on fire if you try it for too long.
