Surface 3 charging issues
2015-05-06T14:21:00+00:00
I'm sure the Surface 2 and other models suffered from this problem...
After getting my Surface 3 yesterday, I plugged it in as it was delivered with about 24% batter life.  The little white light on the micro-USB charger than comes with the Surface lit up.  I assumed all was well, and started the Windows Updates.  It was taking a while so I left it and went to bed.
The next morning the Surface was off, and when I tried to switch it on the battery symbol appeared that indicates it had no juice.  It was still plugged in to the charger and the plug was still lit.
I removed it a couple of times and eventually it must have started to charge as it allowed me to boot, and I could see it was charging.
However, whenever I plug it into any other USB port to charge it (such as on my PC), I get the "Plugged in, not charging" message).
I suspect a faulty micro-USB connector (a poor replacement for the old magnetic ones), but wanted to see if anyone elese was having trouble with either the supplied charger or charging from other USB ports.
Surface | Other
2015-12-17T00:35:26+00:00
MA_905,
Thanks for the update and sorry for the delay in following up.
I am reaching out to find out if your issue is now resolved and if not, I would like for you to please give the two button shutdown a try.
Here’s how:
Step 1: Press and hold the power button on your Surface for 30 seconds and then release it.
Step 2: Press and hold the volume-up button and the power button at the same time for at least 15 seconds and then release both.        <br> <br><br>The screen may flash the Surface logo, but continue holding the buttons down for at least 15 seconds.
Step 4: Press and release the power button to turn your Surface back on.
 Once done, please proceed to fully charge the device and let us know your outcome.
2015-05-06T16:58:56+00:00
what's more likely is that the USB ports that you've used can't provide enough power to charge the device.
2015-07-22T16:55:03+00:00
On Wed, 22 Jul 2015 16:31:18 +0000, quadtek wrote:
>> This is a surface 3, not a pro3
take a look at
http://www.microsoft.com/surface/en-us/support/warranty-service-and-recovery/surface-wont-turn-on#shutdown
  • this applies to your Surface 3
Barb
Windows Experience MVP
2016-03-05T11:51:47+00:00
did you try the solutions at https://www.microsoft.com/surface/en-us/support/warranty-service-and-recovery/surface-wont-turn-on-battery-wont-charge?os=windows-10 ?
If yes, your best option is to go to a physical retail Microsoft Store if you are near one in the US, and if not near a store https://www.microsoft.com/surface/en-us/support/contact-us
2015-12-17T00:48:32+00:00
I contacted MS and they helped me in this one. I had to do a current update. when this did not fix it I had to a a factory reset. then do the update battery life is now as expected.
337 additional answers
    2015-05-06T18:40:48+00:00
    Thank you, Barb and LCRT for helping the customer.
    Hi stephend-,
    Thank you for sharing your experience with us. The links Barb provides have good troubleshooting steps and they are very informative. After reviewing them, if you believe your Surface 3 power supply is faulty, our assisted support can be reached here.  Regarding the message you've got when your Surface 3 is plugged into a power source other than an electrical outlet,  you might find the following steps I extract from our support article Surface Pro and Surface 3 battery and power helpful.
    Charge Surface 3
    Step 1:     Plug the Micro USB connector into the Micro USB charging port with the power cord extending downward and the light on the connector facing toward you.
    Step 2:     Plug the full-size USB connector on the other end of the cord into the power supply.
    Step 3:     Plug the power supply into an electrical outlet.
    Let us know if you have other questions or concerns.
    Kind regards,
    Clare
