Keyboard on new Surface Pro 11 does not always pair with unit upon startup
2024-08-24T16:52:33+00:00
I am on my second keyboard/cover for my new Surface Pro 11 and am experiencing the following issue: On some startups -- not the majority of them -- the keyboard does not pair with the Surface Pro unit. The only solution has been to detach the keyboard from the unit and reattach it. I have cleaned the contacts (although this issue arose almost immediately out of the box after purchase), and followed a few other suggestions that I found online. One thing I have not done is reinstall the drivers. I can't imagine that they are out of date and a check of each says that they are up to date and the best drivers for the unit.) So, my question is this: if two different, new keyboards have experienced the same problem, does it sound like the issue is with the Surface unit itself? And if so, what other remedies are there before I turn it over to an expert?
    2025-06-18T13:46:34+00:00
    Well, it worked for me until this week. Idk what broke it again ...
    Either KB5060842, KB5063060 or the firmware update (Microsoft Corporation - System Hardware Update - 5/21/2025)
    What a shitshow
    2025-06-18T17:47:57+00:00
    I have the same problem with my Surface Pro 11 and the keyboard I purchased for it at the same time. For the amount of money you people charge for a simple keyboard, the damn thing should work properly! I should not have to detach and reattach the keyboard every time I start my computer! I've done the chat thing with Microsoft Support twice and am tired of wasting my time to try and fix a defective product that you peddle. I'd be happy with a solution that works.
    2025-06-18T17:50:15+00:00
    so the problem is with the Surface and not the keyboard?
    2025-06-18T17:57:24+00:00
    Be sure to look at Miles' workarounds. I've referred back to them in some of my posts, too. Still annoying that it doesn't just work right, but at least you can avoid having to detach and reattach the keyboard, causing wear and tear. I use the workaround of pressing the on button before opening the keyboard, and that seems to solve it.
    2025-06-19T01:11:09+00:00
    Definitely with the surface. I tried three different keyboards. European (Swiss) and US
