Keyboard on new Surface Pro 11 does not always pair with unit upon startup
2024-08-24T16:52:33+00:00
I am on my second keyboard/cover for my new Surface Pro 11 and am experiencing the following issue: On some startups -- not the majority of them -- the keyboard does not pair with the Surface Pro unit. The only solution has been to detach the keyboard from the unit and reattach it. I have cleaned the contacts (although this issue arose almost immediately out of the box after purchase), and followed a few other suggestions that I found online. One thing I have not done is reinstall the drivers. I can't imagine that they are out of date and a check of each says that they are up to date and the best drivers for the unit.) So, my question is this: if two different, new keyboards have experienced the same problem, does it sound like the issue is with the Surface unit itself? And if so, what other remedies are there before I turn it over to an expert?
    2024-08-26T18:45:49+00:00
    You and I are in the same boat. I also have the Surface Pro 11 with Snapdragon. Detaching and re-attaching the keyboard does cause the Surface to recognize the keyboard. Usually, pressing the start and volume-up button atop the Surface and holding it down until the UEFI screen appears (it takes a little while) and then exiting without making any changes usually brings the keyboard to life as well. I strongly suspect that the issue is with the Surface and/or Windows 11 on the Surface. If other reports about this same problem come in, Microsoft will have to address it.
    2024-08-26T18:48:55+00:00
    2024-08-26T18:53:09+00:00
    Yes, I really hope Microsoft supports its early adopters and fixes this issue. I like the Surface Pro 11 very much otherwise - and would rather not to the whole "return game."
    Microsoft are you listening? Help?
    2024-08-31T16:43:38+00:00
    Literal same issue with me I find if you turn on fast start up in power options. It works for a good amount of time.
    The keyboard always works in bio. I’m assuming it’s a software issue but I still have two weeks to return this so I don’t know if I will or not.
    2024-08-31T17:35:23+00:00
    Just bought a SP11 and have issue with keyboard not working after a complete shutdown. This happens every time. The only solution is to detach and reattach the keyboard, very annoying.
    Temporary solution is not shutting down the laptop, but just close the lid.
    This is definitely not keyboard problem, but something wrong with the Microsoft driver/firmware. So many users are having the exactly same problem. The old pin type keyboard has no such problem, this new concept keyboard is useless, not many people will use it with keyboard detached.
    Just found out this new keyboard has tiny pins too, so it is physically connected, why is it not working when the windows starts. In bios the keyboard is working good.
