I am also experiencing the exact same symptoms. After 30 minutes of not using the keyboard, I'd come back to find the keyboard is not "waking up". It's happening throughout the day and every time I would need to re-establish the BT connection (unpair/pair).
My setup is:
Surface Pro 7 running Windows 10 2004 (Build 19041.388)
Microsoft Surface Ergonomic Keyboard
This is what I have done…
- Uninstalled Microsoft Mouse and Keyboard Center application
- Unpair (removed) ALL BT devices and removed all other devices in Settings\Bluetooth & other devices
- Restart the PC
- Once all BT devices are removed (completely empty), start adding (pairing) devices one by one
- Installed Microsoft Precision Mouse
- Installed Microsoft Surface Ergonomic Keyboard
- Download the latest version for Microsoft Mouse and Keyboard Center
- Since I am using the Surface Dock 2 it automatically connected…
- Surface Ethernet Adapter
- MX279 (Monitor)
- I also connected my XBOX One
With just the above, so far for the last 24 hours have not experience the behavior. I believe there is an interference with my other BT devices. I am going to adding one BT device at a time and see if the issue comes back. I suspect it's my BT headset (Surface Earbuds) that is conflicting with the keyboard as this is the most recent device I've added. If this is the cause, I will check for updated drivers for the headset.
