2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-01-01T22:49:34+00:00
    Since playing around with the sleep setting my Surface now doesn't actually go to sleep when the lid is closed. The display goes black but the device is on as it continues to generate heat.. In addition there appears to be no way to get the display back on other than forced shutdown and restart.
    This *really* hacking me off now.
    2016-01-01T22:52:22+00:00
    Does it survive a Windows Update? There was the issue that with the new process of automatically updating drivers , windows update undoes any manual updates by reinstalling older drivers. Perhaps that has now been solved?
    2016-01-01T22:53:19+00:00
    When i close the keyboard on my surface and it goes to sleep, and then open the keyboard, it takes a long time for the surface to wake up.
    It has taken from 6 seconds at best to over 30 seconds to become responsive after waking via opening the keyboard.
    Once today it just didnt wake up, i had to hold down the power and reset the device.
    Is this a known issue and is there a resolution?
    2016-01-01T23:22:23+00:00
    I tried the manual install but it decided the best driver was already install, even though the driver you mention is definitely more recent
