2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2016-01-01T20:06:50+00:00
    I used the .zip download from here and manaully did a driver update on the display driver. The automated install .exe will not install because it doesn't think it is a valid system. You need to update the display driver manually through device manager and then click on "have disk" or something to manually pick the driver you downloaded.
    https://downloadcenter.intel.com/download/25620/Intel-Graphics-Driver-for-Windows-7-8-1-10-15-40-6th-Gen-
    By the way, this new driver seemed to have solved the screen waking problem for me.
    I will have to try this.  My dad & I both got the Pro 4's for our business and really like them.  (I think it's the first computer device my dad has called "really cool!").  Not turning on and being readily available on both our machines has been the only problem thus far - but it is a rather big problem if you does it, especially when using for a client.  I did try setting it to hibernate rather than sleep when I close the lid (as suggested by a previous poster) and I haven't had the problem yet - just takes about 15 seconds long to start up, which isn't long at all.
    My only question regarding the driver is that my current driver, dated 11/20/15 is version 20.19.15.4326 and the new driver from Intel dated 12/22/15 is 15.40.14.4352.  Am I looking at the correct update?
    2016-01-01T20:19:24+00:00
    For some reason, the website lists a different driver version, but when I check in windows after the update, I see driver version 20.19.15.4352 so it is definitely newer than the 11/20/15 dated version. That's the right update.
    2016-01-01T20:40:30+00:00
    I just did what you said and you are right.  The driver is now dated 12/15/15 with the driver version you stated.  I hope this fixes the problem.  Thanks!
    UPDATE:  I haven't been able to confirm if it fixes the sleep problem, yet, BUT the streets finally show up in Microsoft Maps!
    2016-01-01T22:33:53+00:00
    I have a new sp4, i7, 16g and was not coming out of sleep like all describe; I uninstalled (did not delete driver) both the display driver and surface display monitor from device manager, rebooted and all seems well so far. Have tested repeatedly with 1 and 2 minute sleep settings. Will change to longer time and report back.
