2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2015-12-29T19:36:53+00:00
    I had the same\similar issue.
    I went into the power settings and advanced power plan settings and slightly changed them, and saved. I then went back in and changed them back to what they were originally.
    Since this change I have yet to have an issue. Note: previously, every time the computer went to sleep I could not get it to wake at all other then hard resetting. It has been ok for the last 4 days. (knock on wood).
    My model is the i7 16gb ram with type cover on it .
    Good to know.
    I have the same model. Since the last updates occurred on mine I haven't had the problem so far.
    It's come out of sleep mode each time I've let it sit for a considerable length of time (about half a day or more)
    I will keep your reply in mind though. Sometimes things get written to the registry differently when done manually as opposed to letting Microsoft update the settings.
    2015-12-29T21:14:56+00:00
    Adding myself to the crowd...I've had the SP4 i5, 8GB, 256GB for 4 days so far, and had the no wake from sleep issue around 4 times, requiring the 30 sec power button to force shutdown.  It's been OK so far today...but it's only 4pm lol.
    Here's something I experienced once so far.  This was prior to upgrading to Build 11586 however, so I'm hoping it doesn't happen again.
    Screen shaking
    I hope things work out with the SP4 because I'd like to keep it, but it's got to be more reliable.  I am hoping to use it in place of an iPad when I do public speaking and presentations.  Last thing I need is to tell the audience to chill while I reboot!
    2015-12-29T22:58:04+00:00
    FYI - SP4 left me hanging twice during public presentations (display freeze, failure to wake)...personally, I am back on iPad for the foreseeable future as a result. I loved the concept of the SP4, but my unit did not seem ready for primetime!
    2015-12-30T00:46:20+00:00
    Just got CRITICAL_PROCESS_DIED.  Nice message.  Rebooting.
