2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2015-12-29T08:01:18+00:00
    I couldn't find the hibernation option for my SP4. Pressing the power button on the start menu just says "sleep", "shut down", and "restart". As for the video driver from Intel, do you mind linking me the download? I'm unfamiliar with these types of things and I wouldn't want to install the wrong driver on accident and cause more damage.
    2015-12-29T13:46:45+00:00
    Check other threads on this issue.  All your questions have already been answered.
    http://www.windowscentral.com/how-force-surface-hibernate
    2015-12-29T13:53:51+00:00
    I see that my Intel graphics driver was updated 3 days ago. I am getting different symptoms since then as far as the wake from sleep problem. Here's what has happened twice now since then.
    The SP4 went to sleep due to me not using it. When I tried to wake it up I get a black screen with the mouse pointer only. I am able to move the mouse pointer around. If I press the power button once the screen is dark black. Press power on again and it is dark blue but nothing on the screen. When I hold the power button to reboot I get part of the logon screen saying to swipe down to reboot. If I swipe down the screen goes black and it does not power off. I had to hold down the power button for 30 seconds to reboot. Then all is fine again.
    2015-12-29T19:13:24+00:00
    I had the same\similar issue.
    I went into the power settings and advanced power plan settings and slightly changed them, and saved. I then went back in and changed them back to what they were originally.
    Since this change I have yet to have an issue. Note: previously, every time the computer went to sleep I could not get it to wake at all other then hard resetting. It has been ok for the last 4 days. (knock on wood).
    My model is the i7 16gb ram with type cover on it .
