2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2015-12-26T16:40:23+00:00
    I had this problem 2 days after purchasing the SP4, after it went to the latest Windows 10 update. It occurred for me a few times a day. I changed my settings to SCREEN off after 10 minutes and SLEEP after 2 hours. For the past 2 days now I have not seen the sleep issue. Since it is intermittent though it will probably recur.
    2015-12-27T13:52:42+00:00
    Well this morning I had a new symptom. Went out for an hour so the screen went to sleep. When I tried to wake it up,  the screen was black but the mouse pointer was visible and I could move it around. I had to do the power off-reboot to get the screen back.
    2015-12-27T22:00:42+00:00
    Someone, perhaps this thread?, suggested Win D several times to close programs, and then alt f4 and enter, to shut down.  Since I've been using hibernate after 1 hour, I haven't had a freeze. But I noticed alt f4 does not work on the surface keyboard plugged in.  This may...Win X to bring up start menu, then u for shut down, and u again to shut down.  I am curious if this will help avoid the power off reboot to get the computer to shut down and restart.  This would be a safer shut down.  Of course, STILL WAITING FOR A REAL FIX. For this and the excessive fan noise/use problem.
    2015-12-27T22:29:15+00:00
    I have just bought the i7 surface pro for over 2000 dollars and the thing will not wake up after it has gone to sleep unless I press the on/off button for many seconds. Really not good!!
