2015-10-27T05:32:42+00:00
2016-08-19T19:27:34+00:00
2,411 additional answers
    2015-12-24T00:44:22+00:00
    it didnt wake up after long sleep! :( this too much
    2015-12-24T00:50:48+00:00
    you called a call center,,, but an actual Microsoft service center for Surface is not available here... This is such a bad experience,, this is my first time to buy a super expensive computer and end up kinda failure... frustrating....
    2015-12-24T11:02:54+00:00
    Exactly. And less people will be buying it if even store models of the SP4 are doing the exact same thing, which happened to me in Best Buy when I checked out the SP4 demo. I have a Microsoft Surface Pro 3 that I bought several months ago, and was considering upgrading to the SP4. But when I went to play with the demo model, it wouldn't turn on. I had to do the multi-step process of power button for 30, power button + volume down button for 15, wait a few, power button on before I could use it. How many people before me passed the Surface Pro 4 by simply because they couldn't turn it on at the store?
    2015-12-25T00:20:48+00:00
    I never had a wake up issue since I bought the device a few days ago, I have updated to 17/12/15 firmware.
    But I still have the battery drain issue in sleep mode, it still seems that the device is not fully sleeping. GPU and CPU are somehow running which consumes about 8% battery during 2 hours sleep before it goes into hibernate automatically.
    I am wondering if wake up from sleep issue only exists in some devices, and clearly a large amount of devices according to this more than 30pages thread. But the battery drain issue should be more seriously existing in every device.
